Error popup when suggesting tags in topic already having tags
When we click the tags suggestion on a topic that already has tags, there’s an error popup.
Doesn’t seem to prevent anything so I don’t classify as Contribute > Bug, but that’s confusing :smile:
Saw this fairly regularly over the past weeks. One thing I noticed is that if you select a tag after that, but exit, the tag shows (but disappears on reload). Other odd behaviour I’ve experienced is the ability to add a tag twice (the second occurence disappears on reload). Does this qualify for Contribute > Bug?
Yeah it’s visible in the video.
Perhaps, but since it doesn’t break or prevent anything and the 2nd tag disappears, I think this applies:
https://github.com/discourse/discourse/pull/38142
Thanks heaps for reporting (btw … I would classify this as bug given there is an actual obvious code flaw)
Thanks for the fix! It was quite annoying to keep seeing the popup.
This topic was automatically closed after 4 days. New replies are no longer allowed.
