Aggiungere un tag a due o più gruppi rompe il tag
Discourse version: v2.1.0.beta5 +66
Self hosted.
This was touched on in an earlier (closed) thread, but maybe the issue wasn’t described fully (it’s definitely a bug, not a configuration error), or the bug has come back:
Problem summary:
If you add the same tag to two or more tag groups, everything looks fine, but any attempt to actually apply the tag to a topic will fail. (At least using the edit-subject-and-tags option at the top of a topic.)
It will look like the tag has been applied to the topic, with it appearing under the title on the page you made the edit on until you refresh the page. Then that tag vanishes. The never appears for the topic on the main topic list, and the topic never appears on the page for the tag. Auto-completion of the tag is also broken.
Workaround:
Remove the tag from all but one tag groups and it will work again.
However, if you do not know this is the cause of the problem or do not notice you added the same thing to two groups, you’ll have a bad time. :slight_smile: (Even more confusing if, like me, you had the tag in three groups and didn’t notice. I found the above thread, tried removing the tag from the new group, but it still didn’t work as it was already broken from being in two others. It was only looking through the database that I realised.)
I figure this must be a bug as it’s not useful or intuitive, and the admin UI does not prevent you from creating the tag-groups situation, while the post-editor lets you use the tag and indicates it thinks it was applied, only to lose it on refresh.
Edit: I just noticed I have another tag which is in two groups and is working, so there may be some extra thing needed to get into this state. I can’t think what, but I’m happy to try anything you can suggest, or dig up info from the database if it’s needed.
1 Mi Piace
Did you check your errors at /logs to see what the actual error is? Sounds like you can’t duplicate this at will, so therefore it’s not quite clear what the bug is?
1 Mi Piace
Nothing under /logs unfortunately. (Last error was 4 hours ago and unrelated.)
It is reproducible.
Here’s a video showing what I do and what happens, creating a new tag that has the same issue:
  1. Add “mtagtest” to three tag groups, saving each group in turn.
  2. Go to a post and try to add the tag.
    Note that it doesn’t autocomplete, but if you type the whole thing you can select it and it doesn’t prompt you to create it as a new tag. So some parts of the system seem to know the tag exists while others don’t.
  3. Save the post and it looks like the tag has applied.
  4. Refresh, and the tag is gone again.
Why it isn’t a problem with my older tag that is in two groups, I am not sure, but I can re-create the problem at will, it seems.
I can’t reproduce this with a tag that belongs to two groups.
Do your tag groups have any restrictions? Do the categories have any tag or tag group restrictions?
My tag groups look like this:
My category tag settings looks like this:
2 Mi Piace
All my tag groups are the same, with no restrictions in the groups themselves.
The “Viewer Plugins” category I was testing with does not restrict tags to a particular group:
But three other forum categories do restrict them:
At the database level:
discourse=> select * from category_tag_groups;
 id | category_id | tag_group_id |         created_at         |         updated_at
  1 |          16 |            2 | 2017-03-20 16:28:47.375592 | 2017-03-20 16:28:47.375592
  2 |          30 |            2 | 2017-08-29 16:49:17.095534 | 2017-08-29 16:49:17.095534
  3 |          11 |            1 | 2017-12-16 10:22:30.399025 | 2017-12-16 10:22:30.399025
(3 rows)
discourse=> select * from tag_groups;
 id |         name         |         created_at         |         updated_at         | parent_tag_id | one_per_topic
  1 | Help Topics          | 2017-01-30 11:55:06.698087 | 2017-01-30 11:55:06.698087 |               | f
  2 | Button/Script Topics | 2017-03-20 16:28:23.544721 | 2017-03-20 16:28:23.544721 |               | f
  3 | Old Plugins          | 2018-08-28 04:31:18.674092 | 2018-08-28 04:31:18.674092 |               | f
  4 | Viewer Plugins       | 2018-08-28 04:55:37.54499  | 2018-08-28 04:55:37.54499  |               | f
(4 rows)
discourse=> select * from category_tags;
 id | category_id | tag_id | created_at | updated_at
(0 rows)
discourse=> select * from tag_group_permissions;
 id | tag_group_id | group_id | permission_type |         created_at         |         updated_at
  3 |            3 |        0 |               1 | 2018-08-28 04:31:18.694836 | 2018-08-28 04:31:18.694836
 15 |            2 |        0 |               1 | 2018-08-28 06:19:24.918843 | 2018-08-28 06:19:24.918843
 16 |            1 |        0 |               1 | 2018-08-28 06:19:33.527234 | 2018-08-28 06:19:33.527234
 17 |            4 |        0 |               1 | 2018-08-28 06:19:40.665686 | 2018-08-28 06:19:40.665686
(4 rows)
discourse=> select * from tags;
 id |        name         | topic_count |         created_at         |         updated_at         | pm_topic_count
 17 | cats                |           1 | 2017-02-03 01:22:57.50731  | 2017-02-03 01:22:57.50731  |              0
 20 | lister              |           0 | 2017-03-20 16:28:23.523937 | 2017-03-20 16:28:23.523937 |              0
 21 | meta                |           0 | 2017-03-20 16:28:23.527058 | 2017-03-20 16:28:23.527058 |              0
  4 | wildcards           |           1 | 2017-01-30 11:55:06.572007 | 2017-01-30 11:55:06.572007 |              0
 15 | translation         |          12 | 2017-01-30 15:24:06.044196 | 2017-01-30 15:24:06.044196 |              0
 24 | perl                |           2 | 2017-08-30 17:56:34.466659 | 2017-08-30 17:56:34.466659 |              0
  7 | dupe-finder         |           1 | 2017-01-30 11:55:06.608334 | 2017-01-30 11:55:06.608334 |              0
 25 | python              |           0 | 2017-08-30 17:56:34.50015  | 2017-08-30 17:56:34.50015  |              0
  6 | synchronize         |           6 | 2017-01-30 11:55:06.599565 | 2017-01-30 11:55:06.599565 |              0
 28 | numbering           |           0 | 2017-08-31 19:15:47.071148 | 2017-08-31 19:15:47.071148 |              0
 29 | characters          |           0 | 2017-08-31 19:15:47.117646 | 2017-08-31 19:15:47.117646 |              0
 31 | multi-col           |           1 | 2018-03-26 22:47:26.978476 | 2018-03-26 22:47:26.978476 |              0
 32 | shell-col           |           3 | 2018-03-26 22:47:27.007196 | 2018-03-26 22:47:27.007196 |              0
  3 | regex               |          18 | 2017-01-30 11:55:06.562673 | 2017-01-30 11:55:06.562673 |              0
 12 | archives            |           3 | 2017-01-30 11:55:06.652326 | 2017-01-30 11:55:06.652326 |              0
 33 | 32-bit-only         |           8 | 2018-08-28 04:31:18.578864 | 2018-08-28 04:31:18.578864 |              0
 44 | not-free            |           3 | 2018-08-28 04:55:37.528065 | 2018-08-28 04:55:37.528065 |              0
 35 | broken-links        |           3 | 2018-08-28 04:31:18.65364  | 2018-08-28 04:31:18.65364  |              0
 34 | superseded          |           8 | 2018-08-28 04:31:18.646539 | 2018-08-28 04:31:18.646539 |              0
 37 | meta-obsolete       |           3 | 2018-08-28 04:41:24.087057 | 2018-08-28 04:41:24.087057 |              0
 38 | opus-native         |           0 | 2018-08-28 04:55:37.490169 | 2018-08-28 04:55:37.490169 |              0
 14 | plugin-development  |          21 | 2017-01-30 12:00:51.563514 | 2017-01-30 12:00:51.563514 |              0
  8 | feature-request     |         182 | 2017-01-30 11:55:06.617124 | 2017-01-30 11:55:06.617124 |              0
 26 | metadata            |           3 | 2017-08-30 18:57:21.776829 | 2017-08-30 18:57:21.776829 |              0
 45 | comes-with-windows  |           1 | 2018-08-28 04:56:20.809373 | 2018-08-28 04:56:20.809373 |              0
 36 | no-unicode-support  |           8 | 2018-08-28 04:31:18.660326 | 2018-08-28 04:31:18.660326 |              0
 16 | 3rd-party-dll-crash |          12 | 2017-01-31 01:18:23.847881 | 2017-01-31 01:18:23.847881 |              0
  2 | rename              |          12 | 2017-01-30 11:55:06.553184 | 2017-01-30 11:55:06.553184 |              0
 19 | column              |          13 | 2017-03-20 16:28:23.520827 | 2017-03-20 16:28:23.520827 |              0
 40 | media-tag-reader    |           2 | 2018-08-28 04:55:37.504437 | 2018-08-28 04:55:37.504437 |              0
 11 | viewer              |          25 | 2017-01-30 11:55:06.644568 | 2017-01-30 11:55:06.644568 |              0
 42 | source-available    |           8 | 2018-08-28 04:55:37.516272 | 2018-08-28 04:55:37.516272 |              0
  5 | find                |           1 | 2017-01-30 11:55:06.584397 | 2017-01-30 11:55:06.584397 |              0
 10 | windows-search      |           1 | 2017-01-30 11:55:06.633681 | 2017-01-30 11:55:06.633681 |              0
 41 | comes-with-opus     |           6 | 2018-08-28 04:55:37.510272 | 2018-08-28 04:55:37.510272 |              0
 30 | events              |           8 | 2017-11-20 22:39:51.680956 | 2017-11-20 22:39:51.680956 |              0
 39 | thumbnails          |          14 | 2018-08-28 04:55:37.498571 | 2018-08-28 04:55:37.498571 |              0
 13 | commands            |         110 | 2017-01-30 11:55:06.660153 | 2017-01-30 11:55:06.660153 |              0
 22 | vbscript            |          34 | 2017-03-20 16:28:23.530339 | 2017-03-20 16:28:23.530339 |              0
 18 | button              |          86 | 2017-03-20 16:28:23.498939 | 2017-03-20 16:28:23.498939 |              0
 23 | jscript             |          49 | 2017-03-20 16:28:23.533286 | 2017-03-20 16:28:23.533286 |              0
  1 | scripting           |         385 | 2017-01-30 11:55:06.537469 | 2017-01-30 11:55:06.537469 |              0
  9 | bug-report          |         219 | 2017-01-30 11:55:06.625241 | 2017-01-30 11:55:06.625241 |              0
 27 | user-interface      |           6 | 2017-08-31 00:45:55.33261  | 2017-08-31 00:45:55.33261  |              0
(44 rows)
discourse=> select * from tag_group_memberships;
 id | tag_id | tag_group_id |         created_at         |         updated_at
  1 |      1 |            1 | 2017-01-30 11:55:06.704593 | 2017-01-30 11:55:06.704593
  2 |      2 |            1 | 2017-01-30 11:55:06.70861  | 2017-01-30 11:55:06.70861
  3 |      3 |            1 | 2017-01-30 11:55:06.711579 | 2017-01-30 11:55:06.711579
  4 |      4 |            1 | 2017-01-30 11:55:06.714741 | 2017-01-30 11:55:06.714741
  5 |      5 |            1 | 2017-01-30 11:55:06.717655 | 2017-01-30 11:55:06.717655
  6 |      6 |            1 | 2017-01-30 11:55:06.720509 | 2017-01-30 11:55:06.720509
  7 |      7 |            1 | 2017-01-30 11:55:06.723438 | 2017-01-30 11:55:06.723438
  8 |      8 |            1 | 2017-01-30 11:55:06.72625  | 2017-01-30 11:55:06.72625
  9 |      9 |            1 | 2017-01-30 11:55:06.729034 | 2017-01-30 11:55:06.729034
 10 |     10 |            1 | 2017-01-30 11:55:06.731797 | 2017-01-30 11:55:06.731797
 12 |     12 |            1 | 2017-01-30 11:55:06.741488 | 2017-01-30 11:55:06.741488
 13 |     13 |            1 | 2017-01-30 11:55:06.747079 | 2017-01-30 11:55:06.747079
 14 |     14 |            1 | 2017-01-30 12:00:51.567893 | 2017-01-30 12:00:51.567893
 15 |     15 |            1 | 2017-01-30 15:24:06.058389 | 2017-01-30 15:24:06.058389
 16 |     16 |            1 | 2017-01-31 01:18:23.875875 | 2017-01-31 01:18:23.875875
 17 |      1 |            2 | 2017-03-20 16:28:23.553505 | 2017-03-20 16:28:23.553505
 19 |     13 |            2 | 2017-03-20 16:28:23.558209 | 2017-03-20 16:28:23.558209
 20 |     18 |            2 | 2017-03-20 16:28:23.559494 | 2017-03-20 16:28:23.559494
 21 |     19 |            2 | 2017-03-20 16:28:23.560835 | 2017-03-20 16:28:23.560835
 22 |     20 |            2 | 2017-03-20 16:28:23.562227 | 2017-03-20 16:28:23.562227
 23 |     21 |            2 | 2017-03-20 16:28:23.5635   | 2017-03-20 16:28:23.5635
 24 |     22 |            2 | 2017-03-20 16:28:23.564923 | 2017-03-20 16:28:23.564923
 25 |     23 |            2 | 2017-03-20 16:28:23.566209 | 2017-03-20 16:28:23.566209
 26 |      3 |            2 | 2017-08-30 17:56:34.455664 | 2017-08-30 17:56:34.455664
 27 |     24 |            2 | 2017-08-30 17:56:34.496446 | 2017-08-30 17:56:34.496446
 28 |     25 |            2 | 2017-08-30 17:56:34.50466  | 2017-08-30 17:56:34.50466
 29 |     26 |            2 | 2017-08-30 18:57:21.783478 | 2017-08-30 18:57:21.783478
 30 |     27 |            2 | 2017-08-31 00:45:55.33669  | 2017-08-31 00:45:55.33669
 33 |     30 |            2 | 2017-11-20 22:39:51.696732 | 2017-11-20 22:39:51.696732
 34 |     31 |            2 | 2018-03-26 22:47:26.995116 | 2018-03-26 22:47:26.995116
 35 |     32 |            2 | 2018-03-26 22:47:27.010827 | 2018-03-26 22:47:27.010827
 36 |     33 |            3 | 2018-08-28 04:31:18.686895 | 2018-08-28 04:31:18.686895
 37 |     34 |            3 | 2018-08-28 04:31:18.690101 | 2018-08-28 04:31:18.690101
 38 |     35 |            3 | 2018-08-28 04:31:18.691548 | 2018-08-28 04:31:18.691548
 39 |     36 |            3 | 2018-08-28 04:31:18.69294  | 2018-08-28 04:31:18.69294
 40 |     37 |            3 | 2018-08-28 04:41:24.093834 | 2018-08-28 04:41:24.093834
 43 |     39 |            4 | 2018-08-28 04:55:37.550546 | 2018-08-28 04:55:37.550546
 44 |     40 |            4 | 2018-08-28 04:55:37.551758 | 2018-08-28 04:55:37.551758
 45 |     41 |            4 | 2018-08-28 04:55:37.552892 | 2018-08-28 04:55:37.552892
 46 |     42 |            4 | 2018-08-28 04:55:37.55414  | 2018-08-28 04:55:37.55414
 47 |     43 |            4 | 2018-08-28 04:55:37.555374 | 2018-08-28 04:55:37.555374
 48 |     44 |            4 | 2018-08-28 04:55:37.55652  | 2018-08-28 04:55:37.55652
 49 |     45 |            4 | 2018-08-28 04:56:20.815517 | 2018-08-28 04:56:20.815517
 53 |     11 |            4 | 2018-08-28 05:17:20.805092 | 2018-08-28 05:17:20.805092
 54 |     47 |            2 | 2018-08-28 06:19:24.906794 | 2018-08-28 06:19:24.906794
 55 |     47 |            1 | 2018-08-28 06:19:33.517114 | 2018-08-28 06:19:33.517114
 56 |     47 |            4 | 2018-08-28 06:19:40.658291 | 2018-08-28 06:19:40.658291
(47 rows)
discourse=> select * from category_tag_stats;
 id | category_id | tag_id | topic_count
  3 |          11 |      8 |         182
  4 |          30 |     22 |          21
  5 |          30 |     13 |           3
  8 |          30 |      3 |          12
  6 |          30 |      1 |          28
 10 |          11 |      6 |           6
 13 |          30 |     24 |           2
 56 |          33 |     36 |           6
 18 |          17 |      1 |           1
 20 |          32 |      9 |           4
 43 |          16 |     26 |           1
 23 |          30 |     26 |           2
 25 |          11 |      4 |           1
 26 |          30 |     27 |           4
 27 |          31 |      9 |           2
 21 |          11 |     16 |          12
 30 |          11 |      7 |           1
 31 |          29 |     17 |           1
 32 |          30 |     18 |           3
  9 |          11 |      2 |          12
  2 |          16 |     19 |          13
 35 |          16 |     31 |           1
 36 |          16 |     32 |           3
 29 |          16 |     30 |           8
 57 |          34 |     44 |           3
 16 |          16 |     13 |          87
 15 |          16 |     22 |          13
 22 |          16 |     18 |          83
 11 |          16 |     23 |          41
 28 |          11 |      9 |         213
 40 |          11 |      5 |           1
 41 |          11 |     10 |           1
 12 |          16 |      1 |          49
 42 |          16 |     27 |           2
 39 |          16 |      3 |           3
 38 |          11 |      3 |           3
  1 |          30 |     23 |           8
 14 |          11 |     11 |           6
 19 |          11 |     13 |          20
  7 |          11 |     12 |           3
 58 |          34 |     36 |           2
 24 |          11 |     15 |          12
 45 |          33 |     33 |           8
 53 |          34 |     40 |           2
 49 |          34 |     11 |          19
 55 |          34 |     42 |           8
 46 |          33 |     35 |           3
 54 |          34 |     41 |           6
 52 |          34 |     39 |          14
 44 |          33 |     34 |           8
 17 |          11 |      1 |         307
 33 |          11 |     14 |          21
 47 |          33 |     37 |           3
 50 |          34 |     45 |           1
(54 rows)
discourse=> select * from tag_search_data;
 tag_id |                           search_data                            |      raw_data       | locale | version
      5 | 'find':1A                                                        | find                | en     |       2
     10 | 'search':3A 'window':2A 'windows-search':1A                      | windows-search      | en     |       2
     16 | '3rd':2A '3rd-party-dll-crash':1A 'crash':5A 'dll':4A 'parti':3A | 3rd-party-dll-crash | en     |       2
     17 | 'cat':1A                                                         | cats                | en     |       2
      6 | 'synchron':1A                                                    | synchronize         | en     |       2
     12 | 'archiv':1A                                                      | archives            | en     |       2
     20 | 'lister':1A                                                      | lister              | en     |       2
     21 | 'meta':1A                                                        | meta                | en     |       2
     26 | 'metadata':1A                                                    | metadata            | en     |       2
      2 | 'renam':1A                                                       | rename              | en     |       2
     19 | 'column':1A                                                      | column              | en     |       2
     11 | 'viewer':1A                                                      | viewer              | en     |       2
      4 | 'wildcard':1A                                                    | wildcards           | en     |       2
     24 | 'perl':1A                                                        | perl                | en     |       2
      8 | 'featur':2A 'feature-request':1A 'request':3A                    | feature-request     | en     |       2
      9 | 'bug':2A 'bug-report':1A 'report':3A                             | bug-report          | en     |       2
     22 | 'vbscript':1A                                                    | vbscript            | en     |       2
      7 | 'dupe':2A 'dupe-find':1A 'finder':3A                             | dupe-finder         | en     |       2
     14 | 'develop':3A 'plugin':2A 'plugin-develop':1A                     | plugin-development  | en     |       2
     25 | 'python':1A                                                      | python              | en     |       2
     15 | 'translat':1A                                                    | translation         | en     |       2
     27 | 'interfac':3A 'user':2A 'user-interfac':1A                       | user-interface      | en     |       2
     28 | 'number':1A                                                      | numbering           | en     |       2
      1 | 'script':1A                                                      | scripting           | en     |       2
     13 | 'command':1A                                                     | commands            | en     |       2
     29 | 'charact':1A                                                     | characters          | en     |       2
     18 | 'button':1A                                                      | button              | en     |       2
     23 | 'jscript':1A                                                     | jscript             | en     |       2
      3 | 'regex':1A                                                       | regex               | en     |       2
     30 | 'event':1A                                                       | events              | en     |       2
     31 | 'col':3A 'multi':2A 'multi-col':1A                               | multi-col           | en     |       2
     32 | 'col':3A 'shell':2A 'shell-col':1A                               | shell-col           | en     |       2
     33 | '32':1A 'bit':3A 'bit-on':2A                                     | 32-bit-only         | en     |       2
     34 | 'supersed':1A                                                    | superseded          | en     |       2
     35 | 'broken':2A 'broken-link':1A 'link':3A                           | broken-links        | en     |       2
     36 | 'no-unicode-support':1A 'support':4A 'unicod':3A                 | no-unicode-support  | en     |       2
     37 | 'meta':2A 'meta-obsolet':1A 'obsolet':3A                         | meta-obsolete       | en     |       2
     38 | 'nativ':3A 'opus':2A 'opus-n':1A                                 | opus-native         | en     |       2
     39 | 'thumbnail':1A                                                   | thumbnails          | en     |       2
     40 | 'media':2A 'media-tag-read':1A 'reader':4A 'tag':3A              | media-tag-reader    | en     |       2
     41 | 'come':2A 'comes-with-opus':1A 'opus':4A                         | comes-with-opus     | en     |       2
     42 | 'avail':3A 'sourc':2A 'source-avail':1A                          | source-available    | en     |       2
     44 | 'free':3A 'not-fre':1A                                           | not-free            | en     |       2
     45 | 'come':2A 'comes-with-window':1A 'window':4A                     | comes-with-windows  | en     |       2
(44 rows)
discourse=> select * from tag_users;
 id | tag_id | user_id | notification_level |         created_at         |         updated_at
  1 |     11 |     199 |                  3 | 2017-02-11 19:58:50.172773 | 2017-02-11 19:58:50.172773
  2 |     14 |   10242 |                  4 | 2017-09-21 02:14:37.388988 | 2017-09-21 02:14:37.388988
  3 |      3 |   11012 |                  4 | 2018-08-08 16:24:27.230327 | 2018-08-08 16:24:27.230327
  4 |      2 |   11012 |                  4 | 2018-08-08 16:24:27.245462 | 2018-08-08 16:24:27.245462
  5 |      8 |   11012 |                  3 | 2018-08-08 16:24:27.256811 | 2018-08-08 16:24:27.256811
  6 |     13 |   11012 |                  3 | 2018-08-08 16:24:27.260248 | 2018-08-08 16:24:27.260248
  7 |     18 |   11012 |                  3 | 2018-08-08 16:24:27.262586 | 2018-08-08 16:24:27.262586
  8 |     14 |   11012 |                  2 | 2018-08-08 16:24:27.271038 | 2018-08-08 16:24:27.271038
  9 |     22 |   11012 |                  0 | 2018-08-08 16:24:27.280543 | 2018-08-08 16:24:27.280543
 10 |      1 |   11012 |                  0 | 2018-08-08 16:24:27.282673 | 2018-08-08 16:24:27.282673
 11 |     23 |   11012 |                  0 | 2018-08-08 16:24:27.284682 | 2018-08-08 16:24:27.284682
 12 |     16 |   11012 |                  0 | 2018-08-08 16:24:27.286522 | 2018-08-08 16:24:27.286522
 13 |      9 |   11012 |                  0 | 2018-08-08 16:24:27.288647 | 2018-08-08 16:24:27.288647
(13 rows)
discourse=> select * from topic_tags;
  id  | topic_id | tag_id |         created_at         |         updated_at
    2 |    15783 |      1 | 2017-01-30 11:56:51.313274 | 2017-01-30 11:56:51.313274
    3 |    20781 |      1 | 2017-01-30 11:56:51.413131 | 2017-01-30 11:56:51.413131
    4 |    23832 |      1 | 2017-01-30 11:56:51.457009 | 2017-01-30 11:56:51.457009
    5 |    24265 |      1 | 2017-01-30 11:56:51.495019 | 2017-01-30 11:56:51.495019
                             ... lots more data ...
 1414 |     1199 |     41 | 2018-08-28 07:14:06.512767 | 2018-08-28 07:14:06.512767
 1415 |     1199 |     39 | 2018-08-28 07:14:06.517445 | 2018-08-28 07:14:06.517445
 1416 |       68 |     11 | 2018-08-28 07:14:29.202551 | 2018-08-28 07:14:29.202551
 1417 |       68 |     42 | 2018-08-28 07:14:29.206621 | 2018-08-28 07:14:29.206621
 1418 |       68 |     41 | 2018-08-28 07:14:29.210458 | 2018-08-28 07:14:29.210458
 1419 |       68 |     39 | 2018-08-28 07:14:29.214275 | 2018-08-28 07:14:29.214275
 1420 |    29761 |      1 | 2018-08-28 19:30:31.690668 | 2018-08-28 19:30:31.690668
(1289 rows)
Questo è un post vecchio ma se sei arrivato qui forse stai avendo un problema dove uno (o più) tag non viene elencato durante la creazione di un nuovo argomento. Ho avuto lo stesso problema, ecco il post a riguardo, commenti, diagnosi e soluzione. Controlla questo link: User cannot create a new topic and tag it during creation - The tags are not listed
