Hi
I got this error when I tried to rebuild app “./launcher rebuild app”
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake assets:precompile' failed with return #<Process::Status: pid 2243 exit 137>
Location of failure: /pups/lib/pups/exec_command.rb:108:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"bundle_exec", "cmd"=>["su discourse -c 'bundle install --deployment --verbose --without test --without development'", "su discourse -c 'bundle exec rake db:migrate'", "su discourse -c 'bundle exec rake assets:precompile'"]}
9a1115f500d5f32060a29064d9b24b0c858f8a511b6e8f5de6523ef0ce642551
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
I found no earlier messages when i scroll up.
I read other posts and I did not find an idea to my issue.
Please find below some params my setup:
docker info
Containers: 1
Running: 0
Paused: 0
Stopped: 1
Images: 2
Server Version: 1.11.2
Storage Driver: aufs
Root Dir: /var/lib/docker/aufs
Backing Filesystem: extfs
Dirs: 16
Dirperm1 Supported: false
Logging Driver: json-file
Cgroup Driver: cgroupfs
Plugins:
Volume: local
Network: null host bridge
Kernel Version: 3.13.0-32-generic
Operating System: Ubuntu 14.04.4 LTS
OSType: linux
Architecture: x86_64
CPUs: 1
Total Memory: 994.1 MiB
Docker Root Dir: /var/lib/docker
Debug mode (client): false
Debug mode (server): false
Registry: https://index.docker.io/v1/
WARNING: No swap limit support
Version of postgressql is 9.3
Thanks for your help
Regards
