Los oneboxes de Facebook / Instagram probablemente fallarán a partir de hoy, 24 de octubre de 2020
Has this been taken care of by the @team?
oEmbed endpoints are now officially deprecated.
I have read about this in some topics here and it was announced by FB a long time ago:
I think a similar approach as for the Twitter oneboxes is required going forward.
1 me gusta
It is in the hands of @sam and @techAPJ
6 Me gusta
Looking at:
This appears to still be working and we are beyond October 24
It appears we are using open graph here:
meta name="description" seems stable even if facebook decide to junk opengraph one day…
I am not really seeing that we need to do anything special here @techAPJ
Is anything actually broken today?
3 Me gusta
The Instagram oneboxing is currently broken here on meta:
https://www.instagram.com/p/CGyuQuwoMFR
… that is even after we updated the Instagram onebox to use OpenGraph tags.
6 Me gusta
Instagram oneboxing is currently broken on our hosted sites as well.
1 me gusta
Is this going to be addressed at some point or in any kind of backlog?
2 Me gusta
Yes it is. No timeline, but I have seen discussion going on. I believe right now we’re working to determine if we can obtain the necessary info to onebox without any credentials, or if we’ll need to follow a similar route to Twitter rich embeds.
6 Me gusta
https://www.instagram.com/p/BZDhAJuFH-b/
We certainly need to debug this (@jamie.wilson is investigating providing better details on why we do not onebox to the end user) … in my case above we have:
        <title>
Amazing Kitchen Gadgets on Instagram: “We have only just caught up on the #GBBO 😱😱 Did you watch it the other night or have you not seen it yet? Tell us your thoughts! 🍰🍰…”
</title>
   <meta content="11 Likes, 1 Comments - Amazing Kitchen Gadgets (@amazingkitchengadgetuk) on Instagram: “We have only just caught up on the #GBBO 😱😱 Did you watch it the other night or have you not seen…”" name="description" />
    <meta property="og:site_name" content="Instagram" />
    <meta property="og:title" content="Amazing Kitchen Gadgets on Instagram: “We have only just caught up on the #GBBO 😱😱 Did you watch it the other night or have you not seen it yet? Tell us your thoughts! 🍰🍰…”" />
    <meta property="og:image" content="https://instagram.fsyd7-1.fna.fbcdn.net/v/t51.2885-15/e35/21688697_318778721927636_8744554647311613952_n.jpg?_nc_ht=instagram.fsyd7-1.fna.fbcdn.net&_nc_cat=108&_nc_ohc=YpwZaaId-vUAX-03OGr&tp=18&oh=3b6a96f126f5841c524572b0ed062678&oe=5FC8972F" />
    <meta property="og:description" content="11 Likes, 1 Comments - Amazing Kitchen Gadgets (@amazingkitchengadgetuk) on Instagram: “We have only just caught up on the #GBBO 😱😱 Did you watch it the other night or have you not seen…”" />
It seems to be to be enough information to build a onebox, we need to debug why we are not getting a onebox here (and we will explain that to end users in a future update)
10 Me gusta
Thanks you for supporting!
1 me gusta
hi, i’m on 66ecefba52f4d907f035bc7c445d98883e1ff792 and something weird is going on with my IG oneboxes, it just creates a single anchor tag with the site domain, then the instagram url which obviously doesn’t exist… now I can’t even disable this behaviour?
i got an app access token from fb/insta oembed via
curl -X GET "https://graph.facebook.com/oauth/access_token ?client_id={your-app-id} &client_secret={your-app-secret} &grant_type=client_credentials"
i tested the oEmbed API w curl -X GET \ "https://graph.facebook.com/v9.0/instagram_oembed?url=https://www.instagram.com/p/fA9uwTtkSN/&access_token=IGQVJ..." and it worked fine… i figured that’s what discourse is using (discourse/spec/components/oneboxer_spec.rb at 331236d6d790dd41538668469f16f853c5699884 · discourse/discourse · GitHub)
nothing useful or related in /logs either… any way i can debug this?
same image on meta:
https://www.instagram.com/p/CHyvKpuFWXH/
tia! :heavy_heart_exclamation:
1 me gusta
Did you add the app access token to the facebook app access token site setting?
i think so, it’s the app id (pipe | ) base64 secret, yes?
edit: it’s working on another discourse instance i manage, with the same creds, so i think they’re fine.
i tried /safe-mode and still no luck, i’m just comparing the settings between instances now
this is what /onebox?url=https%3A%2F%2Fwww.instagram.com%2Fp%2FCHxqj3bMxJc%2F&refresh=false&category_id=15&topic_id=21558 returns:
<aside class="onebox instagram">
  <header class="source">
      <a href="https:/www.instagram.com/p/CHxqj3bMxJc" rel="noopener"></a>
  </header>
  <article class="onebox-body">
    <h3><a href="https:/www.instagram.com/p/CHxqj3bMxJc" rel="noopener">@</a></h3>
  </article>
  <div class="onebox-metadata">
  </div>
  <div style="clear: both"></div>
</aside>
Fixed by removing discourse-onebox-assistant
2 Me gusta
Ooh thanks for the heads up. No time to look at that at mo but will bear in mind when I next get chance. PR welcome.
2 Me gusta
I’ve pushed an update to include the new Discourse code. Hopefully compatibility is improved.
4 Me gusta
