Failed to bootstrap error - problem with pups
Hi folks -
I’ve recently been trying to rebuild our test instance after an update with no luck. Googling/ChatGPT indicates that maybe something is wrong with the app.yml formatting, but I’ve not been able to suss it out. Here’s the stdout, which I realize is not that useful:
x86_64 arch detected.
WARNING: containers/app.yml file is world-readable. You can secure this file by running: chmod o-rwx containers/app.yml
Your version of Launcher is ahead of origin
Stopping old container
app
2.0.20250226-0128: Pulling from discourse/base
Digest: sha256:6f18aa2cd22bba0deb91d69194e577d4f96130ad555ae8ec646a8792cbfe37db
Status: Image is up to date for discourse/base:2.0.20250226-0128
docker.io/discourse/base:2.0.20250226-0128
/usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups.rb
/usr/local/bin/pups --stdin
109:C 13 Jun 2025 15:20:04.997 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
109:C 13 Jun 2025 15:20:04.997 # Redis version=7.0.15, bits=64, commit=00000000, modified=0, pid=109, just started
109:C 13 Jun 2025 15:20:04.997 # Configuration loaded
109:M 13 Jun 2025 15:20:04.997 * monotonic clock: POSIX clock_gettime
109:M 13 Jun 2025 15:20:04.998 * Running mode=standalone, port=6379.
109:M 13 Jun 2025 15:20:04.998 # Server initialized
109:M 13 Jun 2025 15:20:04.999 * Loading RDB produced by version 7.0.7
109:M 13 Jun 2025 15:20:04.999 * RDB age 14 seconds
109:M 13 Jun 2025 15:20:04.999 * RDB memory usage when created 2.95 Mb
109:M 13 Jun 2025 15:20:05.007 * Done loading RDB, keys loaded: 3659, keys expired: 0.
109:M 13 Jun 2025 15:20:05.007 * DB loaded from disk: 0.008 seconds
109:M 13 Jun 2025 15:20:05.007 * Ready to accept connections
3649:C 13 Jun 2025 15:22:52.415 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
3649:C 13 Jun 2025 15:22:52.415 # Redis version=7.0.15, bits=64, commit=00000000, modified=0, pid=3649, just started
3649:C 13 Jun 2025 15:22:52.415 # Configuration loaded
3649:M 13 Jun 2025 15:22:52.415 * monotonic clock: POSIX clock_gettime
3649:M 13 Jun 2025 15:22:52.416 # Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
3649:M 13 Jun 2025 15:22:52.416 # Failed listening on port 6379 (TCP), aborting.
109:M 13 Jun 2025 15:25:05.035 * 100 changes in 300 seconds. Saving...
109:M 13 Jun 2025 15:25:05.041 * Background saving started by pid 3823
3823:C 13 Jun 2025 15:25:05.257 * DB saved on disk
3823:C 13 Jun 2025 15:25:05.257 * Fork CoW for RDB: current 1 MB, peak 1 MB, average 0 MB
109:M 13 Jun 2025 15:25:05.342 * Background saving terminated with success
109:signal-handler (1749828411) Received SIGTERM scheduling shutdown...
109:M 13 Jun 2025 15:26:51.694 # User requested shutdown...
109:M 13 Jun 2025 15:26:51.694 * Saving the final RDB snapshot before exiting.
109:M 13 Jun 2025 15:26:51.710 * DB saved on disk
109:M 13 Jun 2025 15:26:51.710 # Redis is now ready to exit, bye bye...
5b720b35a25e026d9908c60a2f7c5bcf3725b16a0b282875e8a66ce5ace4d06b
I’d like to upload the stderr as an attachment, but as a new user I can’t. Maybe this last bit of the log with the excerpt involving pups is enough?
2025-06-13 15:26:51.615 UTC [42] LOG:  aborting any active transactions
2025-06-13 15:26:51.634 UTC [42] LOG:  background worker "logical replication launcher" (PID 56) exited with exit code 1
2025-06-13 15:26:51.634 UTC [51] LOG:  shutting down
2025-06-13 15:26:51.637 UTC [51] LOG:  checkpoint starting: shutdown immediate
2025-06-13 15:26:51.646 UTC [51] LOG:  checkpoint complete: wrote 15 buffers (0.0%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.001 s, sync=0.003 s, total=0.012 s; sync files=3, longest=0.003 s, average=0.001 s; distance=49 kB, estimate=243 kB
2025-06-13 15:26:51.659 UTC [42] LOG:  database system is shut down
/usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups/config.rb:223:in `block (2 levels) in run_commands': Invalid run command filename (SyntaxError)
	from /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups/config.rb:211:in `each'
	from /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups/config.rb:211:in `block in run_commands'
	from /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups/config.rb:210:in `each'
	from /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups/config.rb:210:in `run_commands'
	from /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups/config.rb:191:in `run'
	from /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups/cli.rb:89:in `run'
	from /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/bin/pups:9:in `<top (required)>'
	from /usr/local/bin/pups:25:in `load'
	from /usr/local/bin/pups:25:in `<main>'
Is there anything else I should look for that would shed some light on the problem? I appreciate your help!
Incidentally, I ran the app.yml file through a YAML linter and it didn’t find anything. I also tried rebuilding without any plugins active, and that didn’t make a difference.
Suggest you paste some or all of your YML file - take care redact passwords and access tokens. The output
does seem suspicious. My own YML file is very simple, no commands, but perhaps yours is complicated.
Thanks @Ed_S. I’ve attached the YML in the hopes there’s a clue there.
app_yml_redacted.txt (4.7 KB)
Thanks. The only thing I can see is that where I have
templates/web.ratelimited.template.yml
you have
templates/web.ratelimited-whitelist.template.yml
Just possibly there is a syntax error in that file? It would be, I think, at
/var/discourse/templates/web.ratelimited-whitelist.template.yml
Although there could equally be a syntax error in any of the other templates mentioned.
I’ve definitely narrowed it down to this file, which is for sure causing the boot failure -
which I’m pasting below (with IPs redacted):
params:
  reqs_per_second: 12
  burst_per_second: 12
  reqs_per_minute: 200
  burst_per_minute: 100
  conn_per_ip: 20
run:
  - replace:
    filename: "/etc/nginx/conf.d/discourse.conf"
    to: |
       geo $limit {
           default 1;
           XX.YYY.ZZ.ZZZ 0; # hubprod
           XXX.YY.ZZZ.ZZZ 0; # hubdev
       map $limit $limit_key {
           0 "";
           1 $binary_remote_addr;
       limit_req_zone $limit_key zone=flood:10m rate=$reqs_per_secondr/s;
       limit_req_zone $limit_key zone=bot:10m rate=$reqs_per_minuter/m;
       limit_req_status 429;
       limit_conn_zone $limit_key zone=connperip:10m;
       limit_conn_status 429;
       server {
  - replace:
    to: |
       location @discourse {
         limit_conn connperip $conn_per_ip;
         limit_req zone=flood burst=$burst_per_second nodelay;
         limit_req zone=bot burst=$burst_per_minute nodelay;
Is there anything in the run command here that looks off? YAML linting still looks OK.
Your indentation is just very slightly different from what I might expect. And you have a blank line at the end. But I don’t know if these are clues.
I think in your place I’d start deleting sections of this YML in a binary search to find the culprit. You have a couple of blank lines, and you have two ‘replace’ sections which you could perhaps remove one at a time. Start by removing major sections and hope you can converge on the problem.
Thanks for your help @Ed_S, it turned about to be some poor indentation buried in the YAML file I mentioned above. Not sure why any of the linters didn’t pick up on it, but diffing the problem file versus one in production made the problem clear right away.
