Fehler beim Neuaufbau nach dem Entfernen eines Plugins
I have installed the plugin below and everything went fine, after testing it i decided to remove it, but when i did and tried to rebuild i got the message below:
Pups::ExecError: cd /var/www/discourse && find /var/www/discourse ! -user discourse -exec chown discourse {} \+ failed with return #<Process::Status: pid 366 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"web", "cmd"=>["gem update bundler", "find $home ! -user discourse -exec chown discourse {} \\+"]}
ff1d279949d22ae0f09f81327fef1065419a7fabfcd9b89cf0fb9f676cb645ba
please advise who i can fix this problem.
update: i did a rebot for the server, the website came back, the plugin is not showing in the app.yml but still showing in the plugins list inside the dashboard.
The plugin is not in the container
but showing in the plugins list inside admin dashboard
1 „Gefällt mir“
Hi Jay,
I just pushed a fix for this to discourse_docker, can you try pulling the latest version (git pull in /var/discourse) and then trying your rebuild again?
4 „Gefällt mir“
I had exactly the same problem.
After your fix i’ve done a ./launcher rebuild app and everything works.
Many thanks :slight_smile:
3 „Gefällt mir“
