Feedback on feature enabling staff to add tags to personal messages
@vinothkannans I have now upgraded and started testing the new feature allowing staff to tag personal messages. I’ve been looking forward to this for a long time and it’s looking good so far! Nice work. :sunflower:
Some things I noticed:
  • :bug: maybe a bug - the tags used by staff in PMs show up in the /tags list, also for regular (and anonymous) users. If a user doesn’t have permission to see tagged messages or topics the tag should not be visible at all to that user. (this is, btw, the case in the tags pulldown search - in my test the tag did not show up there)
  • there is no UI for getting to PM tags and lists of PMs that have a particular tag, except via the link below the message title when looking at a message or message lists. Intuition tells me there should be a https://meta.discourse.org/messages/tags and/or Profile - tobiaseigen - Discourse Meta page
  • there is no bulk action available for PMs to bulk change/append tags which would be hugely helpful to staff trying to get organized with handling a backlog of messages. There are other bulk actions that would also be very handy to have (e.g. bulk delete, bulk assign, bulk solve, bulk add/remove user or group from message, etc).
  • I don’t know if it’s possible to have staff only tags, ideally organized into tag groups for easy management and for limiting who can see them - if so can someone show me how to set this up?
8개의 좋아요
Note @techAPJ will be taking this over as @vinothkannans is busy on other adventures
4개의 좋아요
There actually is (the same Select All/Append Tags functionality works on PMs) but the tag needs to already exist, which is a bug in itself.
1개의 좋아요
Thanks, Hawk, but I don’t see it - there is no admin wrench that I can see in PMs. All I can do is archive. Am I missing something?
Here are my messages with a message selected, including one with a tag. No admin wrench.
and here are some topics with some topics selected, with the admin wrench and bulk actions popup.
So this is interesting. I see the same thing unless I do a search across my inboxes.
Once I have search results I can select them and I get the Bulk Actions modal.
1개의 좋아요
Ah, great! So you mean this - when you do a search of your messages you can then select some messages and see the bulk actions. I see that now and it might help as a start. Thanks! But yes, it would be a help to be able to get to the admin wrench and bulk actions directly when you’re in your messages.
Yup, that’s what I mean.
I agree that it should be by default without search. I think this is a bug.
1개의 좋아요
Personally, I think this behavior you are describing is actually a bug… the bulk actions on the search results should not be showing up for messages at all, because the bulk actions available are for topics, not messages. I wrote about this previously:
3개의 좋아요
Not sure if this is an oversight or purposeful (or I’m missing something), but on the mobile PM list view, tags are not displayed at all. You can only see them if you go into the full message itself, which makes this feature much less useful as an organizational tool if you can only benefit from it on desktop.
5개의 좋아요
Good point. I think it’s just an oversight. @techAPJ?
4개의 좋아요
Yes we should fix this if we can @techapj
2개의 좋아요
Done in
https://github.com/discourse/discourse/commit/83c79af980128b045bd550503fe83bc9b0165568
5개의 좋아요
@tobiaseigen의 제안 사항이 UI에 반영되지 않았습니다. 팀이 메시지를 공유된 이메일 수신함처럼 사용할 수 있다면 매우 유용할 것입니다.
계획이 있으신가요?
감사합니다
1개의 좋아요
맞아 - 일리가 있어. 내가 OP에서 처음 제안한 사항들은 아직 전혀 다뤄지지 않은 것 같아. 방금 확인해 봤거든. 또한 @HAWK가 나중에 지적한 이슈처럼, 고급 검색을 통해 메시지에도 대량 작업이 적용될 수 있어. 실제로 메시지에는 의도되지 않은 작업(예: 여러 메시지를 한 카테고리에 추가하거나 아카이브하는 것)을 수행할 때 예상치 못한 결과가 발생할 수 있어.
