File extensions with multiple periods not processed correctly
Hello
I want to allow people to upload .tar.gz (gzipped tar) on our forum. I have added tgz and .tar.gz as valid file extensions in Settings → Files.
However when I try and upload a .tar.gz file, it is rejected, and Discourse says that acceptable formats include ‘targz’:
Discourse should be able to handle attachments with more than one dot in the file extension.
Cheers
Sam
I think you need to enable the gz extension.
That worked. Thank you :slight_smile:
