FKB Pro - נושא חברתי
This is already known issue, I’m sure, but I’ll push it up anyway: the new sidebar shows only empty space.
I realize FKB Pro shows quite many things that can be found from the sidebar, and location will raise some conflicts, but then the hamburger icon should be hidden.
Hi. Thanks for great job.
We installed FKB Pro theme by default in our self-hosted Discourse about a month ago, configured it, and everything was OK. Yesterday we installed Discourse telegram-auth plugin. Discourse container was rebuilt from the fresh Discourse official sources and updated to 2.9.0.beta10 version. After it we have a big empty space in the right part of the wide screen. Here’s the screenshot: https://www.lubezniy.ru/screens/34a13ea1a87622d4158d85d15d8e9d65372832.png
Can you say, what and where can we do (check, change, report or something other) to fix it? Thank you.
2 לייקים
Hello Victor,
Thank you for the report :slightly_smiling_face:
Here is the fix: Connectors not rendering - #6 by david
It will working after you update your site to the latest version Discourse.
2 לייקים
Greatest thanks, Don. After upgrading, problem was solved.
לייק 1
@Don Hi first thanks for the theme. I use your theme and there are some problems I have.
  1. The label pages look corrupt. There is a shift in the page layout.
  2. For those who use tablets, the left Sidebar is not lost.
I would be glad if you help with these problems
Hello, Can you share some screenshot about the issues? Thanks :slightly_smiling_face:
Little update:
We had a conversation privately and successfully fixed the issues.
The first issue has been fixed via FIX: Modify tag page template to fit to the theme by VaperinaDEV · Pull Request #12 · VaperinaDEV/fkb-pro-theme · GitHub
The second issue was related with google adsense. The ads has fixed size width which cause the issue.
Adding width: 100% to ads in a new component Desktop / CSS seems to fix it.
לייק 1
@Don Thanks for your help
לייק 1
Hi @Don,
Any plans to support RTL out of the box?
i installed this once, and did some CSS work, it does not look pretty when you switch to RTL languages.
Still seems to be a bit broken with the sidebar enabled.
Enabled:
Disabled:
I’m seeing some padding issues as well.
Also some issues are present with the new profile buttons.
2 לייקים
@Don Hi, I am having the same problem. If you could help with this situation, I would greatly appreciate it.
2 לייקים
Hello,
Oh, yeah sorry. I’ve merged an update, to don’t hide sidebar if enabled. Note: This theme is not sidebar ready yet. I have to fix, rethink and refactor lots of thing.
3 לייקים
@Don Thanks for the update
לייק 1
Hello,
I’ve create a bigger update on this theme. I will merge this soon. :slightly_smiling_face:
https://github.com/VaperinaDEV/fkb-pro-theme/pull/13
Changes
  • change layout from flexbox to grid
  • sidebar compatibility
  • new revamped user menu (redesign)
  • clean up the code
  • redesign chat
  • floating navigation controls (notification, create topic button) on mobile
  • desktop version navigation bar on mobile
  • redesign oneboxes and quotes
  • removed avatar and stats (fkb panel) from topic list on mobile
  • removed full width (paddingless) mobile version
Desktop view
Mobile view
Revamped user menu (paddingless redesign)
Desktop
Mobile
Docs
Chat
4 לייקים
Hello,
I’ve added more updates, fixes etc:
  • improve responsive layout
  • added Discourse Reactions support
  • added sticky new topic banner (floating from top)
I testing it a little bit more and after I can merge these changes. :slightly_smiling_face:
Responsive
Sticky new topic banner
Desktop
Mobile
8 לייקים
2 לייקים
Hello,
I’ve merged this Fixes, improvements, sidebar compatibility etc... by VaperinaDEV · Pull Request #13 · VaperinaDEV/fkb-pro-theme · GitHub update and also updated the OP. :slightly_smiling_face:
3 לייקים
Is the reactions fix still valid and needed?
Nope, that is not needed anymore. You can remove. :slightly_smiling_face:
2 לייקים
Hey, awsome theme! :star_struck:
ive got some minor padding issues when using web browser i would like to solve, but dont really know how.
Not on mobile tho! :slight_smile:
לייק 1
Thanks! I glad you like it :slightly_smiling_face: I see this is happens on the experimental new user profile nav. I think this will change a lot in the future, so I will not change the theme for now.
But you can add this to a component.
Desktop / CSS
.new-user-wrapper {
  .new-user-content-wrapper {
    .user-content {
      padding: 1em;
3 לייקים
