Is there any plan to add feature for following users and subscribing for notification if the followed user posts something new? ![]()
I don’t believe there are any current plans to add this functionality to core, but there is a plugin that should achieve what you are looking for:
I guess i need to host dicourse by myself if i want to install this plugin or can business plan cover this?
O.o
That’s correct, the Follow Plugin is not available on our Business plan, so you would need to self-host in order to install it.
Aaah alrighty.Thanks!
One thing to add - depending on the form of notification you are looking for, there was a suggestion made here:
If an RSS feed is sufficient, then you would be good to go on a Business plan.
good point! It seems that it also works with standard plan. But yeah this could do the trick mean while
There just isnt any UI element. need to add the .rss into url ![]()
Discussion can be continued at Watch Users Setting
