discourse-auto-deactivate の単回実行を強制する
Hi all.
I’ve installed the discourse-auto-deactivate plugin and set it to the time frame I’d like. As usual, that’s the easy part. My understanding is that the plugin is on a schedule (timer?) and will run once every 24 hours to determine which accounts are now available for deactivation. Is there a way to manually induce that task, just once, so I can cleanup the user list?
Not sure; a question for @blake!
While I’m still really interested in knowing there’s a way to run that plugin “on-demand”, I did find this thread and that query still worked pretty well so I did get the “initial” clean up done.
You can visit /sidekiq and see if you see the job that needs to be started.
