I forgot my root password and cannot log in when I execute the following command.
ssh root@XXX.XXX.XXXX
Is there a way to confirm or change my password?
Also, do you know the minimum root password requirements for installing Discorse?
I will do my best to remember.
It depends on your host. If itβs digitalocean they have a reset password option on their control panel. Others will have their own way.
Contact the hosting provider to reset it, and i recommand you should using a SSH Key instead of password.
thats work!! thank you @pfaffman .
