Forum shows Oops message
I can’t know.
If the problem is that your app.yml file has some kind of formatting error, it will fix that. You can then go about adding back the plugins.
Copied default app.yml file but still stops showing --retry 3 --jobs 4
Now there is no error in app.yml @codinghorror please help
Sorry not an immediate fix but what about clean rebuild of server and restore from backup? (assuming you have a recent backup?)
This error occurred when I added a plugin URL to app.yml and run ./launcher rebuild app
Nothing was changed except this addition.
Now I have changed app.yml to default but the error still stops rebuild app
I am unable to understand what is wrong with it?
How long did you wait at the bundel installiert point? Depending on your Hardware specs and networkspeed, this could take a while.
Do you fit the hardware requirements?
Same here, mate. Please ping me once you happen to find solution
Likely problems are that you don’t have the right yaml indentation or the plugin you added is broken.
What plugin did you add? What error did you see on rebuild?
