What would you like done?
A small discourse community for our Non-Profit Community that is needing a Discourse forum. We only need it small, like a 10gb max disk size.
When do you need it done?
ASAP
What is your budget, in $ USD that you can offer for this task?
We would prefer it without charge but if that is not possible we would like the lowest possible price.
Minimal servers are only like 5 bucks a month on DigitalOcean.
Here is my Discourse Self-Hosting FAQ – Literate Computing, LLC. It gives basics about self-hosting and options that I provide for setting it up for you.
Ok. I saw on YouTube videos that you had to have the 2GB plan on DigitalOcean for Discourse to run properly. Is that true?
It is if you use their one-click installer, but not if you follow https://github.com/discourse/discourse/blob/master/docs/INSTALL-cloud.md.
Ok. Can I get a free install and just host it myself on my pc, and just pay for the Domain?
Or on an Ubuntu VM?
You’d need a ‘business class’ internet connection to host from home. That’s probably going cost you the same premium as a cloud VPS. I would go for the latter. Scaleway is even cheaper than DO at €2.99 a month for a basic server.
Will this work?
Did you try to follow the official install instructions
It give you $50 to launch your first month
