I ran through the cloud setup guide on DigitalOcean.
The installer seemed to install everything okay, but when I try to open the website in Chrome I get a “too many redirects” error.
It looks like the redirects are pinging from the A record in Cloudflare I added to the IP of the DigitalOcean pod and back again.
You should follow the Discourse official Standard Installation.
It sounds like you have a dns problem, but I can’t guess what.
Your DNS controls should be accessible from the place where you purchased your domain name. Create a DNS
Arecord for thediscourse.example.comhostname in your DNS control panel, pointing to the IP address of your cloud instance where you are installing Discourse.
I followed the above part of the guide and pointed the DNS to the DigitialOcean, but they just redirect to each other now - presumably because the host in the Discourse setup is the A record value so it’s just stuck in a loop.
Turn off the orange cloud. At the A record to your droplet ip. Follow the official obstructions rather then the digital ocean instructions.
Thanks, setting the proxy status to DNS only fixed it!
