Bug not loading categories from mobile:
Default theme
Theme components used:
Installed plugins:
Problem:
Live: https://tavoweb.forum
Default theme
Problem:
Hello
It seems the Category Groups theme component cause this. If you use this component you have to
However if you use other category page style I am not sure this component do something?
Change desktop category page style
setting to boxes with subcategories
or
Disable/remove the theme component the
or
Disable the show on mobile
setting
should fix the problem.
