G-Translate - Fast and easy translate you entire Discourse Forum for free
Greetings on my forum i have created this plugin and if you want it is easy junt install as new component… Many blessings to all.
This doesn’t seem to be a full Discourse theme component. You cannot just install it from its repository because there is no about.json file.
I haven’t uploaded it correctly, I add it manually in after reader and css and that’s it.
That is the direct zip downloaded from my forum.
In order for your component to be published in Customization > Theme component, generally it needs to be installable. I’d recommend following the theme skeleton’s layout (or somewhat of it; not every file there is required for a working component) or it might be moved elsewhere.
You need to use the theme skeleton inputting your code and filling out the about.json
Here is a link to the skeleton
Can you also if able link your site to see it in action?
@Quantic_Aether I see that there is a bunch of configuration already for this in place, like the forum language and translatable languages. Is it possible for you to make these a setting so forum admins can change these defaults?
This works pretty good. Though a better position imho for the button would be the header. It interferes with F-Nav component being fixed position.
The only caveat I found is that if a post is in another language already it doesn’t translate.
Ie my forum is England sh but we do have an area in Chinese.
Send the code to claude.ai and ask it to make changes for you, whatever you want. I have created about 10 100% custom add-ons for my forum and it is just how I wanted it. I recommend them. If you want, I have more add-ons, I will upload them all for free shortly. Blessings to all!
I linked it but they deleted it, it’s 369-forum .com
