Hi,
Can someone give me a tutorial on how to install this on Linux? I’d rather not buy it. I don’t know how much it costs by hand.
So, converted into Euros instead of Dollars.
Regards, Andy
Hi,
Regards, Andy
You can follow this tutorial to install it in a Linux server discourse/docs/INSTALL-cloud.md at main · discourse/discourse · GitHub
dis is free and for the linux server ?
Discourse is indeed free software. As all software, you need some hardware in order to run it.
If you have a linux server already, you can use it. It just need to have a public connection to the internet. If you don’t have one you can get one as cheap as $5 from providers like Digital Ocean.
I don’t understand the instructions, could you at least give me good instructions?
That I can only copy & install it
thanks you !
Those are good instructions. They’re about the best instructions out there. And they do, by and large, let you copy and paste the commands (what few of them there are). If there are specific parts you’re having trouble understanding, I’d expect people here will be happy to help if you’ll explain what you’re confused about. But if those instructions leave you totally lost with no idea of how to proceed, might I gently suggest that this project is a bit over your head at this time?
Somehow everything is messed up, which should be installed first.
I’m sorry, don’t check it somehow. It is totally confusing with all the instructions.
Once your VPS is created, the installation consists of only four commands:
sudo -s
git clone https://github.com/discourse/discourse_docker.git /var/discourse
cd /var/discourse
./discourse-setup
…and if you’re logging in directly as the root user, the first command isn’t even needed. What part of this is confusing?
When I do sudo -s, nothing shows me
and dis
Port 80 appears to already be in use.
This will show you what command is using port 80
./discourse-setup: line 283: lsof: command not found
If you are trying to run Discourse simultaneously with another web
server like Apache or nginx, you will need to bind to a different port
See https://meta.discourse.org/t/17247
If you are reconfiguring an already-configured Discourse, use
./launcher stop app
to stop Discourse before you reconfigure it and try again.
Why don’t you tell us what else you’ve done? Where have you installed this server? What operating system is it using (title, release, etc.)? What else (especially, what other web applications) is running on it? Because the instructions are really intended for installation on a “clean” virtual server; if you have other things going on there, it probably won’t work as well.
operating system
Ubuntu 16.04 LTS (daemon)
Should I switch to 18.04 LTS?
Ubuntu 18.04 LTS (Plain) sounds like a good choice. It’s newer and I’m quite sure the “daemon” of 16.04 means that some kind of webserver is pre-installed, which would explain your current issue with port 80 being used.
So take Okey 18.04 ?
Hopefully it will work because I got the error port:80
Ok, I have it.
Where can I find German speakers?
Do you still have anything installed on your server? I just noticed that port 80 is still being used by a web app. If so, you need to properly distribute your apps using an Nginx proxy and subdomains. I am not an expert or a technician, so I don’t have step-by-step instructions, but you can always search online for how to set up an Nginx proxy with subdomains. So, port 80 must be free for Discourse.
I already have a domain that runs under loudtime.de
