「config file was not found, ensure containers/.yml exists」というエラーが表示される
Everything seemed fine the last time I checked, although I havn’t checked in some time.
Install was done following the official docs, on a DO server.
Rebooted server but same issue.
Tried to run ./launcher restart but get the following error:
Config file was not found, ensure containers/.yml exists
Running ./launcher rebuild produces the same error.
Just noticed the file name of the .yml file should usually be app.yml? I checked the containers folder and the file is named app.yml.
Why is it trying to look for .yml?
The command is
./launcher rebuild app
not
./launcher rebuild
@pfaffman it might be good to add an informative message in this case rather than looking for a blank .yml file.
Well, I’m generally afraid of messing with launcher as it’s the only way to break every install on the planet. :wink:
If you give launcher a file that doesn’t exist it suggests the ones that do. I’m surprised that it doesn’t do that with no argument.
My fears aside, I’ve got one fix to discourse-doctor on my list. I’ll try to add an argument check to launcher when u do that.
That’s true, do you think we can make a “filename exists” check here @tgxworld without breaking stuff?
Done in
https://github.com/discourse/discourse_docker/commit/f80e6a37a9d748f43047141b18986f6386444bc9
