When I get to the stage whereby I should create DB in postgres, I get an error saying the role " " does not exist.
Anyone know what the issue is ?
Not to worry, I needed to create another DB superuser with:
CREATE USER username SUPERUSER;
I have ran bundle install successfully. However when I attempt to run:
bundle exec rake db:migrate db:test:prepare db:seed_fu
I then receive errors:
Kuyashis-MacBook-Pro:discourse Kuyashi$ bundle exec rake db:migrate db:test:prepare db:seed_fu
rake aborted!
LoadError: cannot load such file -- memory_profiler
/Library/Ruby/Gems/2.0.0/gems/activesupport-4.2.7.1/lib/active_support/dependencies.rb:274:in `require'
/Library/Ruby/Gems/2.0.0/gems/activesupport-4.2.7.1/lib/active_support/dependencies.rb:274:in `block in require'
/Library/Ruby/Gems/2.0.0/gems/activesupport-4.2.7.1/lib/active_support/dependencies.rb:240:in `load_dependency'
/Users/Kuyashi/discourse/config/initializers/006-mini_profiler.rb:7:in `<top (required)>'
/Library/Ruby/Gems/2.0.0/gems/activesupport-4.2.7.1/lib/active_support/dependencies.rb:268:in `load'
/Library/Ruby/Gems/2.0.0/gems/activesupport-4.2.7.1/lib/active_support/dependencies.rb:268:in `block in load'
/Library/Ruby/Gems/2.0.0/gems/railties-4.2.7.1/lib/rails/engine.rb:652:in `block in load_config_initializer'
/Library/Ruby/Gems/2.0.0/gems/activesupport-4.2.7.1/lib/active_support/notifications.rb:166:in `instrument'
/Library/Ruby/Gems/2.0.0/gems/railties-4.2.7.1/lib/rails/engine.rb:651:in `load_config_initializer'
/Library/Ruby/Gems/2.0.0/gems/railties-4.2.7.1/lib/rails/engine.rb:616:in `block (2 levels) in <class:Engine>'
/Library/Ruby/Gems/2.0.0/gems/railties-4.2.7.1/lib/rails/engine.rb:615:in `each'
/Library/Ruby/Gems/2.0.0/gems/railties-4.2.7.1/lib/rails/engine.rb:615:in `block in <class:Engine>'
/Library/Ruby/Gems/2.0.0/gems/railties-4.2.7.1/lib/rails/initializable.rb:30:in `instance_exec'
/Library/Ruby/Gems/2.0.0/gems/railties-4.2.7.1/lib/rails/initializable.rb:30:in `run'
/Library/Ruby/Gems/2.0.0/gems/railties-4.2.7.1/lib/rails/initializable.rb:55:in `block in run_initializers'
/Library/Ruby/Gems/2.0.0/gems/railties-4.2.7.1/lib/rails/initializable.rb:44:in `each'
/Library/Ruby/Gems/2.0.0/gems/railties-4.2.7.1/lib/rails/initializable.rb:44:in `tsort_each_child'
/Library/Ruby/Gems/2.0.0/gems/railties-4.2.7.1/lib/rails/initializable.rb:54:in `run_initializers'
/Library/Ruby/Gems/2.0.0/gems/railties-4.2.7.1/lib/rails/application.rb:352:in `initialize!'
/Library/Ruby/Gems/2.0.0/gems/railties-4.2.7.1/lib/rails/railtie.rb:194:in `public_send'
/Library/Ruby/Gems/2.0.0/gems/railties-4.2.7.1/lib/rails/railtie.rb:194:in `method_missing'
/Users/Kuyashi/discourse/config/environment.rb:5:in `<top (required)>'
/Library/Ruby/Gems/2.0.0/gems/railties-4.2.7.1/lib/rails/application.rb:328:in `require_environment!'
/Library/Ruby/Gems/2.0.0/gems/railties-4.2.7.1/lib/rails/application.rb:457:in `block in run_tasks_blocks'
/Library/Ruby/Gems/2.0.0/gems/rake-11.2.2/exe/rake:27:in `<top (required)>'
/Library/Ruby/Gems/2.0.0/gems/bundler-1.12.5/lib/bundler/cli/exec.rb:63:in `load'
/Library/Ruby/Gems/2.0.0/gems/bundler-1.12.5/lib/bundler/cli/exec.rb:63:in `kernel_load'
/Library/Ruby/Gems/2.0.0/gems/bundler-1.12.5/lib/bundler/cli/exec.rb:24:in `run'
/Library/Ruby/Gems/2.0.0/gems/bundler-1.12.5/lib/bundler/cli.rb:304:in `exec'
/Library/Ruby/Gems/2.0.0/gems/bundler-1.12.5/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/Library/Ruby/Gems/2.0.0/gems/bundler-1.12.5/lib/bundler/vendor/thor/lib/thor/invocation.rb:126:in `invoke_command'
/Library/Ruby/Gems/2.0.0/gems/bundler-1.12.5/lib/bundler/vendor/thor/lib/thor.rb:359:in `dispatch'
/Library/Ruby/Gems/2.0.0/gems/bundler-1.12.5/lib/bundler/vendor/thor/lib/thor/base.rb:440:in `start'
/Library/Ruby/Gems/2.0.0/gems/bundler-1.12.5/lib/bundler/cli.rb:11:in `start'
/Library/Ruby/Gems/2.0.0/gems/bundler-1.12.5/exe/bundle:27:in `block in <top (required)>'
/Library/Ruby/Gems/2.0.0/gems/bundler-1.12.5/lib/bundler/friendly_errors.rb:98:in `with_friendly_errors'
/Library/Ruby/Gems/2.0.0/gems/bundler-1.12.5/exe/bundle:19:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
Tasks: TOP => db:migrate => environment
Could anyone assist please ?
Hmm. Did you
bundle install
@pfaffman yes, when ran bundle install I got:
Bundle complete! 99 Gemfile dependencies, 185 gems now installed. Use bundle show [gemname] to see where a bundled gem is installed.
.. but that was before running:
I still get the above error even though it says bundle completed ..
Try doing:
cd ~/discourse
source ~/.bashrc
bundle install
many thanks @techAPJ ![]()
