Rake db:migrate fails on OSX and VirtualBox
AI 生成的摘要
Two users are experiencing issues with running rake db:migrate on OSX and VirtualBox. ralinchimev reports an error related to a missing file /var/lib/gems/2.2.0/gems/ember-data-source-2.3.0.beta.5/dist/ember-data.js. Mihai_Raulea confirms a similar issue on Mac OS X El Capitan.
Hello,
I’ve tried to setup my dev environment on my Mac but failed.
Then tried using Vagrant on VirtualBox following the instructions exactly. But on both I get this same error:
[vagrant@precise32:/vagrant (master)]$ bundle exec rake db:migrate
rake aborted!
Errno::ENOENT: No such file or directory @ rb_sysopen - /var/lib/gems/2.2.0/gems/ember-data-source-2.3.0.beta.5/dist/ember-data.js
/var/lib/gems/2.2.0/gems/ember-rails-0.18.5/lib/ember_rails.rb:68:in `block in <class:Railtie>'
/var/lib/gems/2.2.0/gems/railties-4.2.6/lib/rails/initializable.rb:30:in `instance_exec'
/var/lib/gems/2.2.0/gems/railties-4.2.6/lib/rails/initializable.rb:30:in `run'
/var/lib/gems/2.2.0/gems/railties-4.2.6/lib/rails/initializable.rb:55:in `block in run_initializers'
/var/lib/gems/2.2.0/gems/railties-4.2.6/lib/rails/initializable.rb:54:in `run_initializers'
/var/lib/gems/2.2.0/gems/railties-4.2.6/lib/rails/application.rb:352:in `initialize!'
/var/lib/gems/2.2.0/gems/railties-4.2.6/lib/rails/railtie.rb:194:in `public_send'
/var/lib/gems/2.2.0/gems/railties-4.2.6/lib/rails/railtie.rb:194:in `method_missing'
/vagrant/config/environment.rb:5:in `<top (required)>'
/var/lib/gems/2.2.0/gems/activesupport-4.2.6/lib/active_support/dependencies.rb:274:in `require'
/var/lib/gems/2.2.0/gems/activesupport-4.2.6/lib/active_support/dependencies.rb:274:in `block in require'
/var/lib/gems/2.2.0/gems/activesupport-4.2.6/lib/active_support/dependencies.rb:240:in `load_dependency'
/var/lib/gems/2.2.0/gems/railties-4.2.6/lib/rails/application.rb:328:in `require_environment!'
/var/lib/gems/2.2.0/gems/railties-4.2.6/lib/rails/application.rb:457:in `block in run_tasks_blocks'
Tasks: TOP => db:migrate => environment
Any clue?
Regards,
R
same here, i am on mac os x el capitan
