GitHub Plugin API error 301
DanEss reports encountering persistent Discourse::GithubApi::Error with status 301 in the logs. This error prevents the configuration of a new github_linkback_access_token, as attempts to save the token result in the same 301 error, making it impossible to verify if the issue is transient or permanent. The user includes screenshots illustrating the error messages encountered during the token setup process.
I’ve been seeing a number of errors in the log reporting a 301 error with the GitHub API.
Discourse::GithubApi::Error: GitHub API error (status 301)
I’m not able to set a new github_linkback_access_token due to the 301 errors and can not save the access token in case this is transient. Any attempts to save that value reports said error.
