Eerste gebruikers een "Founder" status geven
In a discussion titled “Giving first users a ‘Founder’ status,” thibault seeks advice on recognizing early forum members. Suggestions include using a badge or group-based flair instead of manually assigning permanent titles, allowing users to choose their display title (e.g., “Regular” or “Founder”) based on trust level Thomas_G. Several users caution against the term “Founder,” suggesting alternatives like “Founding Member,” “Devoted,” or “First User” to avoid implying ownership IAmGav. Qursch recommends creating a “Founders” group with custom titles and flair, which JimPas supports, noting that group-based flair is automatic while titles are user-selectable. thibault agrees with the feedback and plans to implement a group-based solution. The consensus favors flexibility, clarity in terminology, and user choice in displaying recognition.
Hi!
I’m new to Discourse and I just set up my first Discourse forum.
I want to do something nice for my first users, so I figured it would be a nice touch to give them a permanent “Founder” status.
How would be the best way to approach this? Should I just manually update the user title of the first 25 users to “Founder” or is there a better way to do this (with a badge or something?)
Thanks!
Sounds like a great idea. If I were you, I would create a badge (which could be used a a title) instead of a permanent title. The reason behind it is that users might reach TL3, meaning that they might want to have Regular as their forum tag. Having said that, they will be able to choose between Regular or Founder
On a side note: You sure you want to use founder? It kind of makes me think that one is the actual founder of the forum, not one of the first members that joined. I’d use something like Devoted or First User/ Member or Longstanding :wink:. Of course that’s up to you though, just my 2 $.
You should make a Founders group, where you can allow users to have a custom title and possibly a flair.
I would rather call it “founding member”. Not Founder
You can still name the group “Founding Member” and use a badge or flair as mentioned above by @Qursch. Make “Founding Member” available as a title and the user can use after their username. The use of any available titles are up to the user to initiate in their preferences, but the flair is automatic once they are added to the group.
Fair point about not calling it “Founder”, thanks!
Gonna try it with a group, thanks guys :slight_smile:
