I’m seeing the following error when verifying why google ads are not displaying.
Refused to load the script 'https://pagead2.googlesyndication.com/pagead/js/adsbygoogle.js' because it violates the following Content Security Policy directive: "script-src 'unsafe-eval' 'report-sample'
I’m not a coder or anything. I’ve tried some suggestions for adding meta tags for Content Security Policy but those seem to break the entire site even more.
Any suggestions? I’m using the default Light theme with a version 2.3.0.beta9 that is used on Digital Ocean marketplace.
I’ve tried both. I installed the official ads plugin and added my own google script code in the /head under customizations.
I just discovered the content_security_policy setting as well and disabled it, was still getting errors but that was with my script in the /head, disabling that now and trying with the plugin settings.
For anyone who runs into the same issues, steps to get ads going seems to be:
Disable content_security_policy
Make sure the official Ad plugin is installed and active.
Create ad unit’s for mobile and desktop to place in the ad settings for use.
Seems if you try doing meta http-equiv="Content-Security-Policy" in your head tags, it still complains about the policies if the security policy is enabled in the admin settings.
È un po’ fastidioso che venga proposto un plugin per gli annunci, ma non vi sia alcun riferimento alla configurazione di CSP nel plugin per gli annunci. Immagino che tu debba avventurarti nella wilderness dei bug, vero?
Perché non informare gli utenti nel file README del plugin per gli annunci che è necessario configurare CSP?
Il plugin per gli annunci dovrebbe gestire automaticamente le voci CSP per AdSense o per la piattaforma pubblicitaria pertinente.
L’attivazione predefinita della CSP è una novità relativamente recente e rappresenta una funzione di sicurezza importante, quindi dovremmo aggiornare la nostra documentazione.
