Hello if you go to /groups as a normal user you can manage groups all groups I imagine this probably isn’t meant to be happening ![]()
לייק 1
We suspect this is a UI problem where that control is showing up when it shouldn’t.
Can you check a few things?
- try removing me from that group
- does it still show up if you refresh the page?
- does it still show up if you do a hard reload?
לייק 1
Ok, I will try those things now.
Right so the good news is I can’t remove you from the group. Originally I didn’t want to press anything. However the UI still appears after a refresh and hard refresh.
לייק 1
A few more:
Do the controls only show up for this group?
What browser are you using?
If you log in via Incognito mode, does it still show up?
לייק 1
it happens to all groups
Chrome - Desktop only. can’t repro on mobile
It still shows in Incognito.
לייק 1
Ah, @Osama found the problem. This button:
shows up for all users and brings up the group management tools. It shouldn’t be showing up for everyone.
10 לייקים
@cvx, can you add that to your list?
3 לייקים
