Problemas ao renomear grupos e remover proprietários de grupo
I noticed that there is a bug in the new group management functions.
(just migrated to the latest release Version v2.0.0.beta6 +52 2.0.0.beta6 but I had this problem already in one of the latest beta5 builds)
  • it looks like capital letters are no longer supported in group names
    I renamed a group that had the group name “NRW-DiB-Tische” to “NRW-Aktionsteam” and the system showed that the group name is available, but after clicking on the save button and a reload it is then “nrw-aktionsteam”
    But the existing groups are still in capital letters:
  • I could add additional owners to the renamed group but I cannot remove the existing owners. Clicks on remove as owner does not remove the old owners
2 curtidas
I also faced problem with group owner removal. the logs are as following:
fatal:
log.txt (12.0 KB)
warning:
warning.txt (11.9 KB)
just installed the latest release Version v2.0.0.beta6 +102
Error does still exist
V2.0.0 beta8 has the same issue. I have added new owners, used the Remove as Owner option in maintenance to remove myself as owner, but it does not remove me.
Is it that I can no longer remove myself, as I successfully did prior to the upgrade?
My groups that I am trying to modify have capitals in their names.
1 curtida
Oops this is a regression. Fixed in
Fixed in
5 curtidas
This topic was automatically closed after 27 hours. New replies are no longer allowed.
