Hamburger-categories widget does not mount?
Following the docs here Developing Discourse Themes & Theme Components
The example using the log works fine but when I update the widget to
{{mount-widget widget="hamburger-categories"}}
Nothing comes out… I’ve run through the list at https://github.com/discourse/discourse/tree/main/app/assets/javascripts/discourse/app/widgets. and some widgets show some don’t?
Eventually i want to use just the categories list as buttons inside a custom header, like this…
Have you got the new sidebar activated? That will hide the old hamburger menu.
Confirm your site setting is so:
I had it set to “Header Dropdown” I changed it to “Legacy” but same issue
The hamburger menu shows, but I am after just the categories
{{mount-widget widget="hamburger-menu"}}
Apologies I was thrown by the widget name. What plugin outlet are you using?
the same as in the docs
<script type="text/x-handlebars" data-template-name="/connectors/below-footer/fancy-footer">
  <div class="footer">
    <div class="wrap">
      <p>before mounting a widget</p>
        {{mount-widget widget="home-logo"}}
      <p>after mounting a widget</p>
    </div>
  </div>
  </script>
theme is here GitHub - tpximpact/bcn-discourse-theme I tried it on https://discourse.theme-creator.io/. and problem remains
If you look at the guide you can see the plugin outlet takes an attribute showFooter. That’s probably false. Meaning that neither the footer nor the attached widget will show.
In any case why a footer outlet for a header artefact?
Use the plugin outlets theme component to pick a better location imho.
It does show… it shows widget=“home-logo”
and it also shows widget=“hamburger-menu”
but it doesn’t show widget=“hamburger-categories”
Just testing it out, doesn’t really matter where it is right now
Any errors in the console?
What shows in the inspector?
I can see categories here, so they do exist…
My guess is this is the problem:
There’s no attribute categories being passed via the footer outlet
but when i use widget=“hamburger-menu” in the footer outlet it shows the categories
I’ve tried other outlets around the page and problem persists
Had you posted that error message initially it would have saved a lot of time.
Always look at the console.
You may need to attach this one with JavaScript once you have retrieved the list of Categories in the same way the Hamburger menu does it.
yeah definitely and even more time if the documentation didn’t say “Now, mounting a widget is pretty simple, all you need to know is the widget’s name. That’s it”
Yeah my hunch is that guide is out of date?
Do you know where I can find the most up to date guide, I’m flying around in here trying to find answers but landing on posts that are 4 years old. Is there an actual guide document somewhere?
Yeah I can see how that would be misleading… technically it does mount the widget, but that doesn’t mean the data required by the widget is automatically available.
You can try passing the categories into the widget this way:
{{mount-widget widget="hamburger-categories" args=(hash categories=this.site.categories)}}
Great thanks… yes that makes sense and is showing now
As we are here talking about logging in the console
When following the docs Beginner's guide to developing Discourse Themes
When i try
    console.log(Discourse)
</script>
I’m not sure I get a “global object to the console”, I get a class
And if i try something like
  const settings = Discourse.SiteSettings;
 console.log(settings)
</script>
I get this error
THEME 6 'BCN Theme - watched locally'] Deprecation notice: use injected siteSettings instead of Discourse.SiteSettings
