JSey
(Joe Seyfried)
Setembro 15, 2015, 5:49pm
1
Continuing the discussion from Feedback on new and user menus :
Cool, thanks @Simon_Cossar - hope that fix gets picked up soon…
…and here’s another
Currently, if the categories list is sufficiently long, you cannot scroll the dropdown far enough to click on “Desktop view” - scrolling stops before the text of that link becomes visible, rendering that function useless. .ember-view .menu-panel .slide-in is simply some pixels too high.
I will add this as a separate bug report and add some imagery: when on mobile view and with a sufficiently long category list, this happens:
…you cannot scroll further down because the .ember-view .menu-panel .slide-in is too high. If you’re lucky and your device has a more pixles in y-direction, you can see the whole menu as usual:
(on mobile, you lose the desktop switch link instead of the keyboard shortcuts).
3 curtidas
tgxworld
(Alan Tan)
Setembro 16, 2015, 4:16pm
The following is related too. We’re fetching too many notifications.
2 curtidas
JSey
(Joe Seyfried)
Setembro 17, 2015, 6:30pm
3
Re-using this one since it’s closely related. On FF ESR 17, the menus become inaccesible when they go from drop-down to slide-in. You get neither any hover effects nor can you click the menus.
ESR 38 works, however.
1 curtida
simon
Setembro 17, 2015, 8:04pm
4
That’s probably a separate bug. The slide-in menu doesn’t scroll at all on FF ESR 17.
sam
(Sam Saffron)
Setembro 17, 2015, 9:06pm
5
This is working now, @eviltrout fixed it, FF 17 is a separate issue and different dinosaur that is keeping 2012 alive!
3 curtidas
