Users discuss UX issues with the hamburger menu toggle in Discourse’s sidebar. PhilFoss notes the icon doesn’t visually change to a ‘close’ state when the sidebar is open, causing confusion, and shares CSS code to dynamically swap the hamburger for a close icon. denvergeeks suggests moving the close button inside the menu with a back arrow and “Close Menu” text. Canapin and pfaffman argue that a prominent close button is unnecessary for users who keep the sidebar enabled, proposing instead that the sidebar collapse to a narrow strip (like Cloudflare) rather than disappear entirely. JammyDodger raises a valid concern: if the toggle is hidden in a collapsed sidebar, how do users reopen it? pfaffman acknowledges this oversight and suggests the collapsed strip should remain visible. Lilly defends the current top-right mobile placement to avoid accidental logo taps. Comparisons are drawn to Gmail’s implementation, where the hamburger remains in the top-left but the sidebar content changes, and to a custom Ghost CMS site using hover-to-expand features. denvergeeks praises the hover interaction, though Lilly cautions against hover-dependent UI on touchscreens. PhilFoss reports the hover solution is buggy on mobile. Alternative icons like indent/outdent are suggested by Don, and denvergeeks points to Flarum’s design. satonotdead argues these issues warrant attention from the Core team, as they hinder adoption for non-technical users. Meanwhile, Lilly has created a theme component to address the dynamic icon issue, and David_Chao confirms shared interest.
Hello, I’m new to Discourse and hope this is a helpful observation- the hamburger menu never changes to a ‘close’ ui so I’ve found myself clicking it thinking I’m about to reveal more stuff, but it closes unexpected. It was already open. I’ve got a few lines of css that I plan on adding as a topic in the ‘theme component’ category when I have more access. Luckily the codebase has proper classes so we can hook onto those based on the sidebar showing or not showing.
Thank you for this! I would also suggest that the X Close button be moved to inside the Menu itself, at the very top. (In that position I would also add “Close Menu” text to the button, and perhaps use a left-pointing arrow instead of the X.)
I think most people use Discourse with the sidebar always enabled (I’d be curious to see stats on various forums). Having a large X that encourages, sort of speaking, of closing a part of the layout that is basically permanent for many users would look a bit weird to me.
Seems like someone who knew a bit more than I about CSS (or maybe the DOM?) could make a theme component pretty quickly, but probably the thing is a PR that fixes the template.
So maybe collapsing the sidebar rather than removing it is a solution. Then if you know what the icons/colors are, you can use it without having it expanded.
Pretty much every site makes the home/icon at the upper left, and having the hamburger there seems wrong.
I know this is a different thing but I suspect the side-burger icon is still top right in mobile because on a small touchscreen, I can see tapping the logo by mistake would be a common thing if it were top left beside like on desktop view. Although same could be said about it being near avatar and search icons.
I’ve not really played with it before, but it also has an ‘expand on hover’ thing going on too which is quite nice.
I think they have a more distinctive set of icons, which makes deciphering it when collapsed easier than a first glance at Meta’s one leads me to think. Though if you start adding in things like multiple labels then it does suffer the same ambiguity our tags might have:
no to hover tags and category names. hovering is not ideal for touchscreen interfaces either. using desktop mode with hover stufff on an iPad doesn’t really work well.
I like the hover, as long as the screen tap behaves the same as with a mouse.
Here’s one of my favorite style, on a highly customized Ghost CMS site I built for a client, where hovering anywhere over the sidebar slides open the vertical stack of click/tap links to reveal cascading submenus… it feels very smooth and easy to navigate. You can try it out here:
