Update from 1.9.0.beta3 (I think!) caused a problem when moving to 1.9.0.beta11 (where I’m currently).
I have a quick link to latest at header, one left from the search button. The problem is that the upgrade changed the size of the icon. It used to be the same size as the other icons, but after upgrade (which I did a few weeks back, didn’t get around to fixing the problem, though…) it changed in size.
Another question, I wonder if you might have an idea: it seems that the lightning is bright white, whereas the other icons are not so bright. How might I achieve a similar dim color to the lightning?
