RGJ
(Richard - Communiteq)
February 27, 2016, 11:05am
1
We’re building a Sitemap plugin and I’m running into an issue.
(Yes there has been a lot of discussion around the need for a sitemap, but Google News totally requires it)
Somehow the code in the controller is never executed and I get the regular “The page you requested doesn’t exist or is private” message.
Because I suspected an issue with the view, I have stripped the code so it should only output a log line and an error, but this doesn’t work either.
Code is here:
https://github.com/communiteq/discourse-sitemap/blob/master/plugin.rb#L20-L26
Running it does this:
If I rename the generate method or change the route, I get an error that the controller could not be found, so I should be on the right path here. Is there anyone who can spot (the probably very trivial) issue?
zogstrip
(Régis Hanol)
February 29, 2016, 11:48am
Why do you have two routes for get "sitemap.xml" ?
RGJ
February 29, 2016, 12:23pm
3
I have now monkey patched robots_txt to make it work, and commented out the part that references the engine.
This is the commit you should be looking at
EndruK
(André Karge)
April 13, 2016, 1:39pm
4
Did you get it to work?
I got exactly the same problem, that my controller method code never gets called but the application knows the controller and his methods.
Regards
RGJ
April 13, 2016, 3:22pm
5
No, I was never able to get that fixed
EndruK
(André Karge)
August 5, 2016, 8:36am
6
You need a client route as equivalent for a server route
https://meta.discourse.org/t/custom-home-page-to-discourse/12329/2?u=endruk
And on the client you have to call the server controller:
I’m not sure you can display views through controllers without an Ember route map. The only time I’ve called Ruby controller methods is through ajax calls. Take a look at the plugin how-to and look at the section where Robin talks about the route map.
Hope this helps you
RGJ
August 5, 2016, 9:42am
7
robots.txt is requested by search engine bots, not by the user.
So there is no need / use for an Ember route map…
