תמיכה ב-Hetzner S3
What is the current status of support for S3 object storage on hetzner.de? There is an older topic for this at https://meta.discourse.org/t/is-hetzner-object-storage-and-bunny-cdn-supported/355282 but the information for the setup seems to be incomplete yet. The admin UI for the S3 setup is currently focused on AWS. I am unshure how I can use these settings for S3 storages at other providers environment.
I assume I need the access key and secret plus the bucket name and the S3 endpoint. Correct?
You can take a look at this and see if it helps. I don’t see Hetzner in the conparison table though.
אני משתמש ב-Hetzner כ-Backup Bucket.
עם זאת, אני רוצה לציין ש-Hetzner אינו מציין זמן פעולה (uptime) מפורש, מסיבה זו אני משתמש בו רק להעלאת נתונים.
Yeah. Judging from the Hetzner status page and what I read on the Hetzner subreddit, their S3 storage doesn’t have the same quality as their other offerings yet. I’m sure they’ll eventually get there, but right now, semi-regular downtimes are to be expected.
