S3 OVH Object Storage
Hi,
Does anyone use OVH Object Storage (S3) (Solution de stockage d’objets (Object Storage) | OVHcloud France) ?
It is supposed to be S3 compatible, but Discourse (2.6) only show “Aws::S3::Errors::BadRequest”
Regards,
לייק 1
hum :thinking: No, but I was wondering the same thing… did your setup previously work with another host ? What configuration did you use in your app.yml ?
Hi,
I’m afraid, i don’t have app.yml ? I make the install via https://github.com/bitnami/bitnami-docker-discourse
well… I’m afraid the bitnami install is not supported, I can only point you toward:
לייק 1
OK thanks, I will try to reinstall and let you know.
לייק 1
Hi,
I did not reinstall, but solved by manually update the param ‘S3_region’ in postgres database (table site_settings).
Si it works fine with OVH and scaleway. :ballot_box_with_check:
3 לייקים
