Hiding/deleting topic "about the xxx category"
Users are discussing the issue of hiding or deleting a topic “about the xxx category” in a category. testingsoftware found that the topic cannot be deleted, even though it asks for confirmation of deletion, but instead can be hidden. They suggest that the system should display an error message saying “you cannot delete this topic” or “this topic is linked to the description of your category and cannot be deleted”.
Others, including fefrei and jomaxro, agree and suggest that a proper error message should be displayed. They also found another path to attempt deletion via bulk actions, but it still doesn’t work.
The suggested solution is to display an error message saying “Cannot delete ‘about this category’ topics. X other [topics/posts] deleted” when trying to delete multiple topics, including the undeletable one. fefrei and testingsoftware think this would be a good solution. However, codinghorror suggests that the deletion can simply be skipped in this case, without creating extra busywork to cover a rare situation.
Hi all,
I was trying to delete the topic “about the xxx category” because I have some categories that don’t need description.
Thanks to codinghorror and schungx i realised that it cannot be deleted but just hidden away from users which is not my ideal but it does work and allows for future use.
When trying to delete it even asks for confirmation of deletion but it does nothing, the topic just remains selected.
Wouldn’t be more user friendly if:
  • it’d say “you cannot delete this topic” or “this topic is linked to the description of your category and cannot be deleted”
  • allow deletion if description not added when creating category or simply Admin wants to delete it.
Where do you see the option to delete this topic? It doesn’t show up for me:
Select Posts
Click “delete” selected and it will ask for confirmation of deletion
After OK it remains as the first screengrab
Ah, good catch! This should be fixed and show a proper error message.
I also found another path, via bulk actions:
How would this work? If I select 20 topics including the about category topic, and click delete, what exactly happens next?
I tried only selecting the About topic (as you can barely see in the background). Deletion appears to work (without any confirmation) but has no effect.
A good reaction would be an error message stating that About topics cannot be deleted. (If multiple topics were selected, I’d go for deleting the other topics and showing an error message.)
That was what I was curious about (should have been more specific).
Just tried and it does delete the topics marked except for the “about the category”. and indeed, without confirmation of deletion as Felix says.
So if I understand both of you correctly, you’d be happy if there was an error message that said something like:
Cannot delete “about this category” topics. X other [topics/posts] deleted.
That would be perfect :heart:
(That, plus a similar error message for trying to bulk-delete posts including the undeletable original post as per @testingsoftware.)
That sounds good.
It would work for either trying to delete only the description topic and if trying with more at the same time.
:+1:
Not needed, the deletion can simply be skipped in this case (for batches). Otherwise we are creating extra busywork to cover a pretty rare situation.
Leaving it like this is fine with me as I know now how the software behaves. Although it is good practice to have feedback for actions that cannot be done or not allowing users get that far.
