How can I add a message to the login modal?
Hi there! I would like to be able to add a permanent message like the attached image. Please, how could I achieve that? Thanks!
Simplest way is a css customization, using the before or after text Insertion option.
Like Jeff mentioned, CSS is the easiest way. Here is an example of what you could add to the common.scss
#login-form::before {
    content: "My Custom Message";
    color: red;
Which would give you this result:
Thanks guys! That’s what I needed.
