Hi everyone,
I want to know how I can change the navigation tag’s name: Latest, New and Unread.
I want to change them into Japanese.
If anyone knows the way to change, please help me.
Thank you and best regards.
Saori
Hi everyone,
Saori
‘Latest’, ‘New’ and ‘Unread’ should be translated. This is what I get on this forum when I change my locale to ‘ja’:
Maybe you need to either set the forum’s locale to Japanese, or set your locale to Japanese in your settings?
Oh, Thank you very much
I will try it.
I have checked my settings, and I found my language is Japanese.
Do you know how can I change those topic into Japanese?
something seems to be wrong here, but a fast temporary solution can be using
admin/customize/site_texts and translating those strings into Japanese.
you’ll need to search “top” for example, and then write a Japanese string there.
Thank your your kind reply
I will try it.
I checked admin→customize→text contents→Latest, New, Unread
but all of them are in Japanese…
no idea! perhaps someone more technical may be able to help.
just some guesses:
Thank you thank you!!
I will try it. I hope I can solve this problem ASAP.
