Do you have any query for Data explorer?
I need to calculate the impact of my ambassador group
Is this close?
That one doesn’t allow you to specify the group id as a parameter
Yes man, how can I filter for group_id?
I think a JOIN with the group_users table ON user_id WHERE group_id should do it.
group_users
id serial primary key
group_id integer fkey groups
user_id integer fkey users
created_at timestamp
updated_at timestamp
owner boolean default false
notification_level integer default 2
