When I found “bear out” in my discourse, “bear out” in the title didn’t come to the top.
Can I change the setting so that topics that match perfectly come to the top?
Did you try it in quotes? That makes it a very specific, in-order word match. Search for
"bear out"
versus
bear out
See if that helps. There are other advanced search options on the search page such as “matching in title only” that might be useful as well.
which is equivalent to adding in:title to your search.
