I’ve seen this a couple of times but can’t figure out where to set this up. I looked at category settings and then under featured box but it doesn’t do anything. Or is this only possible with custom css?
Any pointers?
Creating a Popular Topic Sub Banner
The discussion revolves around creating a popular topic sub banner, similar to the ones seen on EventTribe and FeverBee. Carsten_Pleiser initially asked how to set this up, but HAWK clarified that it’s not possible through the UI and requires custom CSS.
Carsten_Pleiser attempted to create a sub banner and shared a draft, but encountered an issue where the page would jump back to the top when clicking on a tag. robmc suggested that this was due to the CSS being applied across all pages.
Carsten_Pleiser eventually fixed the issue with a CSS ‘hack’ that hides the homepage overlay when clicking on a category. The solution is not perfect, but it’s a nice enhancement.
In summary, creating a popular topic sub banner requires custom CSS, and Carsten_Pleiser has shared a potential solution, although it may require further refinement.
Any pointers?
Hi Carsten,
In that particular case, yes. That isn’t done through the UI.
You can have subcategories display as tiles through the UI as we have done in howto
Would that suit your purpose?
Okay, I’ve seen it on EventTribe and FeverBee (exactly the same type) so I thought it was somehow possible. No problem. I think I might need to do some custom styling. The above would not necessarily suit I think.
Thanks for your speedy reply @HAWK.
I designed and commissioned that one. It’s custom CSS and was done by @joebuhlig
Here’s the draft - I’ve built this last night. Weird thing, though, whenever I click on a tag, for example, the page jumps back to the top (which is slightly annoying). Would anyone know how to fix that?
Forgot the link
https://forum.foundersandcreators.com/
@Carsten_Pleiser looks good - how did you do it, and was it complicated?
Just plain CSS and HTML. Still working in it and once it’s ready, I can share the CSS with you if you like?
Can anyone explain why it always jumps back to the top?
I presume this is because you have added this CSS to the header across all pages, whether they are results of tag or category filters, so the page will always default to TOP and load the full header
I think that if you look at Feverbee, the ‘header’ is only on the home page (and includes a way to hide it) but when you click on the boxes, you load a new template .../tags/... or .../c/... where that header is not loaded
Maybe that helps?
Thanks @robmc for pointing this out. That was exactly it. I have fixed it with this little ‘hack’:
body[class*="category-"] #homepage-overlay {
display: none;
Not the nicest solution as the image still shows for a millisecond when clicking on the category, but a nice enhancement.
Top. Thank You! ![]()
