How do I disable the hot feature?
I would rather just shut this feature off - my community is new / small and labeling things hot seems kind of pathetic and distracting - there are barely any people here
Are you using the Horizon theme? If so, I believe post labels can be disabled, not able to check but I think I remember the option existing.
If you’d like, you can also remove it from the top navigation menu in the admin panel
Thanks - I removed the hot category. I don’t see an option to remove the labels… I’ll see if it comes up again
