Hoe log ik in op mijn Admin-account
The discussion revolves around a user, bacionBOI, who has installed Discourse on Digital Ocean but is having trouble logging into their admin account. fzngagan suggests that an email should have been received with login details, but bacionBOI claims not to have received it.
fzngagan asks if an email was set up during installation, to which bacionBOI responds that they did not receive a prompt to do so. fzngagan suspects an issue with the SMTP configuration, and bacionBOI asks how to access the setup file.
fzngagan recommends running ./discourse-setup to start the setup again. bacionBOI asks for guidance on configuring the SMTP server address and provides the website they are using. Stephen explains the importance of proper email configuration and provides resources for setting up email with Discourse.
The conversation also touches on the topics of SPF and DKIM records, spam filters, and Let’s Encrypt. bacionBOI mentions using SendGrid and still being unable to find the email sent by Discourse.
I finished installing the discource on digital ocean.
And it It’s installed
But how do I login?
You should have received an email.
What Email.
My real email?
or my SMTP email.
You should have got a prompt to set an email for the account while installing right?
No, I did not.
30char
I did not get the email, and I check it again.
Then its a problem with your smtp config.
Ok, but how do I get the file then?
./discourse-setup
should start the setup again
I started the setup, so what should I put in SMTP server address?
The website that I am using?
Also, can you give me an example for what should I put?
No you need to specify SMTP account you have created for which ever mail provider you have selected.
Email
:warning: Email is CRITICAL for account creation and notifications in Discourse. If you do not properly configure email before bootstrapping YOU WILL HAVE A BROKEN SITE!
Source: Cloud install guide
Does your inbound mail have SPAM filters? Be sure to check the junk mail box.
(Have to include the basics.)
How do I get lets encrypt?
If you have a valid DNS entry and your server is accessible across the internet without any proxy server it should be configured automatically.
I can’t even find my email from the discourse that was sent to me.
I am using SendGrid by the way.
