Each URL in Discourse has a number as follows.
Does it affect the result of Google search?
If not, should I leave it as it is now? How do numbers in each URL in Discourse work?
Why would it?
You can’t change it anyway.
It depends on the URL, but most of the times it’s the id of the “thing” you’re viewing (be it a topic, a post, a user…)
Hi Regis,
Thanks for your explanation!
