How do to view rails errors?
A discussion on viewing Rails errors in a Discourse setup. iamphi is developing a plugin for custom redirects and is having trouble adding routes, resulting in a 502 Gateway error. He found the Rails log location (/shared/log inside the container and /var/discourse/shared/standalone/log outside) and david suggested visiting /logs on the forum for a web interface to view the Rails log.
Additionally, pfaffman mentioned that permalink settings and the vbulletin.rb importer can be used to achieve similar results. However, iamphi pointed out that the importer may not handle VBSEO links. pfaffman is working on modifying the importer to create permalinks and allowing for normalization to handle VBSEO links.
I am writing a custom plugin to do redirects for my old vbulletin+vbseo forum urls. The import script doesn’t handle the url formats created by vbseo.
I have a docker+discourse setup.
I have created blank plugin with just the meta data stuff (name, about, version author), and used sv restart unicorn to get the plugin loaded; it shows up in the admin panel. Beyond that I am having trouble doing more. When I try to add a route, nginx/discourse would return 502 Gateway.
Where can I view errors related to my plugin? or learn more about adding routes in discourse (I assumed it is like adding routes to a rail app)?
Thanks.
I found the rails log location. Inside container /shared/log, outside container /var/discourse/shared/standalone/log
You can also visit /logs on your forum to view the rails log in a web interface
Are you aware that there are permalink that you can set to do this and that the vbulletin.rb importer will create them?
I’ve seen that section of code in the importer and I don’t think it’ll handle vbseo links like:
http://vbforum.com/forum/sub-forum/12345-the-thread-title
Oh. I’m a bit behind on getting PMs submitted.
I modified the importer so that it creates permalinks like /showthread/12345. You can then use permalink_normalizations to re-write /forum/sub-forum/12345-the-thread-title into /showthread/12345, which then does the Right Thing.
Looks like I need to clean up the code a bit before I can submit it.
thought of this thread when i saw this:
