How i can reset page counter of the leaderboard plugin?
If that need do at db , is there some plugin to explore db , for not attach to docker container and do all with cmd via postgres db cli ?
This what i mean
i was delete 2 test leaderboards and now count start from 3 :neutral_face: ,1 and 2 is empty pages.
Like the topic, user and post IDs those are always increasing and backed by a PostgreSQL sequence.
You will need to drop into a psql shell in order to reset it.
i undestand that , but qustion i need simple drop it at
public | gamification_leaderboards            | table | discourse
or some where else to need clear ?
( problem , i cannot find table where that value is )
Its not in a table but in a sequence, which is the mechanism PostgreSQL uses to store auto incrementing IDs for primary keys.
PostgreSQL docs should cover this operation.
./launcher enter app
sudo -u postgres psql discourse
for list all
SELECT * FROM information_schema.sequences;
ALTER SEQUENCE gamification_leaderboards_id_seq RESTART WITH 1;
ALTER SEQUENCE gamification_scores_id_seq RESTART WITH 1;
