Hello,
In Discourse, Can we create sub category of subcategory?
Example:
Category>Sub category>Sub sub category>Sub sub subcategory> tag1> topic 1
Thank you!
The discussion revolves around setting up subcategories in Discourse. huynhthai824 initially asked if it’s possible to create subcategories of subcategories, with an example of a five-level structure. RGJ and Mevo explained that, by default, Discourse only allows two levels of subcategories, and adding more levels is not possible.
However, Mevo suggested a workaround by using a combination of categories and tags. For example, using categories for location (Country > Province/City > District) and tags for type trade and type property.
huynhthai824 expressed concerns about the search functionality, as users usually search by type trade and type property before location. Mevo clarified that categories and tags work in parallel, and it doesn’t matter if users select tags before or after entering categories. Additionally, Mevo suggested that modifying the display of the search boxes (tags and categories) might be possible through a theme or CSS.
I would use tags if I were you.
But, if you really want to, you can do it. Just remember that there will be no one to dry your tears.
Look here. Sub-sub-categories - #7 by Michael_Uray
That seems 1 level more than what’s possible. You cannot do “3x subs”.
Default = Cat+Sub cat.
By option (given by Richard) = Add “Sub sub”
3x subs = Now you’re asking for too much ![]()
Not much, i need more upto 5 level
Example:
Type trade
Type Property
Country
Province/City
District
Street
Tags are your friend
Tag not strucTure stree,
Street not same level with district, city and country.
More, in a country have alot of street same name in other city
Not gonna happen, I recommend using a different software.
Is it not possible to implement such a thing through a plugin?
Ok, then:
Category = Country
Sub cat = Province/city
Sub sub cat = District
Street = in the topic title, people can use the search function.
Or you have to couple 2 of of your category needs together. The 2 where there is less categories. You seem to already want to do this with Province/city. You could do:
Cat = Country/Province
Sub cat = City/District
Sub sub cat = Street
Type trade and type property = Tags
It seems doable if you adapt yourself a little. Or you need to dig in the plugin possibilities, or another forum software.
I thought that, but user usually search type trade and type property before search location.
I wonder question that how move search menu tag before category https://meta.discourse.org/t/can-we-fix-structure-tag-before-category/173701
There is no “before” or “after”. They work in parallel (category and tags). It doesn’t matter if a user selects tags before or after entering some specific categories.
If they enter the categories they want, and only select the tags after, in the end, it will be the same. Categories won’t just be filtered by tags while they enter them, but it probably isn’t very important.
If you mean just the UX, the display of the boxes to select them, I guess that must be possible to switch pretty easily: Tags to the left of categories selection, and not to the right. Though a theme or CSS.
