How to add a pixel which fires when any user registers?
The discussion revolves around adding a Facebook or Google AdWords image pixel to track user registrations on a Discourse forum. divine seeks a way to fire a pixel when users register, as these platforms only support image-based tracking. codinghorror suggests using a webhook, but divine clarifies the need for client-side execution. eviltrout questions the approach, noting server-side signals are more reliable. divine explains that ad platforms restrict server-to-server communication, necessitating a client-side solution. Mittineague asks about the context, and divine confirms it’s for remarketing. simon recommends placing the pixel code in the HTML customization section under </head>, which eviltrout supports as a viable workaround. dylanh724 suggests placing it on the main page for remarketing, while SouperC notes their pixel works in the body tag and recommends using a Chrome pixel checker for validation.
Hello
We need to add a facebook image pixel which is fired when the users register. Any idea on how can we do that?
Thanks!
Any suggestions to it?
What you want is a webhook, not an image request.
As I understand, ‘webhook’ is for the server (where discourse is installed) to send HTTP requests after a certain event. On the other hand, I want to place a HTML/Javascript code which executes from the client-side when he registers. Is this something which a webhook can do?
The question is why do you want to do it this way? Wouldn’t it make more sense to have the server send a signal once the user registers, rather than a hidden pixel which is less reliable?
It is because Google Adwords and Facebook Ads only allow us to place image pixels and don’t allow server-to-server communication.
Are you saying you have advertisements on the registration modal?
We want to advertise our discourse forum on Google Adwords and Facebook Ads. They allow us to place an image pixel when a conversion takes place (in this case a user registration). This allows them to optimize our ad campaigns and show our ads to users who are more likely to signup. Does that make sense?
Here is more information on how to use image pixels for conversion tracking:
https://www.facebook.com/business/help/460491677335370
It sounds like you want the script to fire on this page:
Maybe you can paste the pixel code in here (admin/customize/text-content).
This should work and would be a great place for the tracking code.
Ideally this would be done via Javascript in the adwords plugin for you, but this is a nice workaround.
Apologies to bump, but it would be best when visiting the main page. It’s not for direct advertising - for remarketing later. For example if someone visited your forum, they are at least SOMEWHAT interested in what you have to offer, whether they register or not. That’ll allow FB pixel to send signal to remarket later.
EDIT: I placed it at admin >> customize >> css/html >> html customization >> under </head>. Is that right?
Ho impostato il mio codice Pixel nel body; non so se sia una cosa buona o cattiva, ma funziona da tre anni. Puoi installare il Pixel Checker per Chrome per convalidarlo.
Tracciare solo le iscrizioni potrebbe essere più complesso.
