Is there an easy way to add contact us page in discourse?
Adding a Contact Us Page in Discourse
@asugar is looking for a way to add a contact us page in their self-hosted Discourse setup. @ondrej suggests that every Discourse site has a contact us section in the About page, but @asugar finds this approach inconvenient.
@itsbhanusharma recommends using either an external contact page or the page publishing feature in Discourse to create a contact page. However, this would require users to have an account.
@Jonathan5 shares a link to a topic on creating a contact form in Discourse, but @jimkleiber points out that this method would likely require users to have an account.
@jimkleiber eventually suggests using the Landing Pages Plugin to create a contact us page with a form that sends an email to a defined email address. This approach does not require users to have an account.
The About - Discourse Meta page of a Discourse site has a contact us section
Hi @asugar
Would you like to host the page on discourse or externally?
If you want an external page, there is a theme component which can be used to link an external page.
If you want a page to be hosted on discourse itself, discourse has support for page publishing which can be adapted to provide contact information.
As mentioned by @ondrej the /about page already contains basic contact info so it might be redundant.
It’s first time I’m using this script and I must say I’ve never seen such a messed up way to setup simple things. A visitor/user of forum is not a psychic who will know where to look for contact info by going to About and then scrolling down. I even didn’t know there was About page link which takes you away to pages. Why don’t just stick it in header or footer like any other script? Why everything is such a pain in the a$$ to work with in this script?
I’m not taking about Meta about us, I’m talking about adding a Contact us page on my self hosted setup.
Ok, I understood it now. I was asking about adding a contact form on contact us page.
The easiest way would be to use the personal messages or group messages in that case.
I wonder if this approach would require people to have an account, compared to most website contact forms which allow any visitor to send a message.
Does the custom wizard plugin allow non-users to fill out the forms? If not, is there a way to use incoming mail / reply-by-email to create an HTML contact form that will send an email to an email that connects with Discourse?
The answer is probably No.
Discourse requires an account to allow the usage of almost all the features.
That’s why I shared the option of linking to an external contact page / contact form
It seems possible to add a contact us page using the Landing Pages Plugin ![]()
See the following link to learn more about how to set up the contact form:
This partial lets you render a contact form which will send an email with the submitted message to defined email. There are two site settings you can use as the email endpoint.
- The
landing contact emailsetting will be used if set.- The
contact emailsetting will be used if thelanding contact emailis not set.Both the
messageare required parameters, so if the user does not include valid version of either, an error message will be returned.
