I am giving users rewards for posting high quality topics on the forum. The metric I am using for high quality posts is likes from the community. However, this leaves the window open for users to collude and like each other’s posts to get more rewards.
I want to avoid that by checking what percentage of likes given by a user were concentrated to just one user? I am also using the daily likes given limit to restrict mass likes.
People must have faced this issue in their forums but I could not find a feature or a topic that addresses this issue. Can someone please share your experience or point me to an existing resource if I missed it?
So there’s not a direct feature that you can see the percentage, at least I don’t think, but you are able to go into their likes column and see what posts they have liked. In their profile, you can go to the activities tab and go down to like. There it will show you what posts they have liked.
If you really do want to see the percentage, you can post in Marketplace and someone can make a plugin/theme for you (if you’re willing to pay for someone to do it.)
Thanks Robert. The visualization looks great. I have decided to write a SQL that checks for likes_given distribution per user and use it to grant or withhold rewards.
The trick here is some people could come back and say - hey, I just follow these 5 people and 1 of them is a very active poster and I like this author’s work. I am not biased, I genuinely like the posts.
Lot of nuances here but only way to sort this out is by seeing how it actually works.
