I’m trying to install the Discourse Math Plugin. It is the 1st plugin I install. Discourse runs on a very modest VM under GCP.
I edited the app.yml file like this:
hooks:
after_code:
- exec:
cd: $home/plugins
cmd:
- git clone https://github.com/discourse/discourse-math.git
After running ./launcher rebuild app I got the message down below from my VM, complaining about memory, and my plugin still does not show in my discourse settings so it does not seem to have installed it. Does the message below mean that, because of the lack of memory, nothing could actually happen? I am surprised that 5 GB is not enough to download the plugin. Anyway to check if the download happened? Or is that just my app.yml that I didn’t edit properly?
root@discourse-gcp1:/var/discourse# ./launcher rebuild app
WARNING: We are about to start downloading the Discourse base image
This process may take anywhere between a few minutes to an hour, depending on your network speed
Please be patient
2.0.20200512-1735: Pulling from discourse/base
Digest: sha256:7f6c5be23a8e4237cecafaca9d041de5964f8237345b7b183cebdee1f73ed024
Status: Downloaded newer image for discourse/base:2.0.20200512-1735
docker.io/discourse/base:2.0.20200512-1735
You have less than 5GB of free space on the disk where /var/lib/docker is located. You will need more space to cont
inue
Filesystem Size Used Avail Use% Mounted on
/dev/sda1 9.6G 5.3G 4.4G 55% /
Would you like to attempt to recover space by cleaning docker images and containers in the system?(y/N)y
If the cleanup was successful, you may try again now
