כיצד להשבית את הבדיקה של "נראה שהגוף לא ברור, האם זו שאלה שלמה?"
סיכום מבוסס בינה מלאכותית
The discussion revolves around disabling the “Body seems unclear, is it a complete sentence?” checker in Discourse. rahim123 has tried adjusting various settings but was unable to disable it. Stephen suggested using the reactions plugin as an alternative to posting short replies like :-). Meanwhile, dmitry_fedyuk shared a plugin implementation that can disable the feature. anon48433008 agreed that a plugin is the only way to disable the setting and expressed the need to enter short code replies in special use forums, advocating for the option to be suggested in the preview window rather than restricting replies.
I’m struggling to turn this off, I have set:
  • allow uppercase posts → enabled
  • title prettify → disabled
  • body min entropy → 0
  • title min entropy → 0
  • min post length → 1
  • min first post length → 1
It still won’t let me post a reply of just :-)
לייק 1
Why not use the reactions plugin instead?
That way you aren’t defeating the features which promote productive conversation and small reactions like emoji won’t bump topics.
2 לייקים
Interesting option, thanks.
In principle I would still like to know if it can be disabled, because our community is pretty laid back in that sense. I imagine that Discourse doesn’t consider punctuation to count toward the entropy or character length count?
לייק 1
I have implemented it with a plugin:
לייק 1
A plugin is the only way to disable
I have need to enter three digit code replies and also wish to disable this setting, I wouldn’t mind it suggested in the preview window but to restrict the option to reply is just not good when there are special use forums that operate different than the norm, even such as
לייק 1
